2011 honda civic 4 dr sedan
Old Jun 9, 2021
brishardi's Avatar
brishardi is an unknown quantity at this point
Hello im new to this forum and I appreciate any help here..Thank you
Can someone tell me where to start on with the removal of the coolant cross pipe, is it the water pump side or egr side, Do I need any special tools for pipe?
what is removed on start?
Old Jun 9, 2021
Re: 2011 honda civic 4 dr sedan
not an engine performance modification...
moving to proper section of the forums
Old Jun 10, 2021
BrotatoChip's Avatar
Super Moderator
Anything that's in the way, probably the entire intake manifold. It will slide out of the water pump so you need the other end loose first.
Old Jun 11, 2021
brishardi's Avatar
Thanks for reply is there a certain type lube for the o rings?
Old Jun 14, 2021
Super Moderator
On other engines with a similar coolant pipe I spray the seal with WD-40 before trying to slide the pipe back in.
adovbush
Mar 1, 2021 01:54 PM
jasminej145
Jun 4, 2016 05:55 PM
plasmaok
Jan 13, 2013 03:26 PM
roger t
Oct 28, 2010 06:53 PM
Civicster
May 15, 2002 01:40 AM
