Sudden drop in MPG
Old Mar 11, 2021
Webguy64's Avatar
Webguy64 is an unknown quantity at this point
Sudden drop in MPG
I've always gotten between 35-39MPG in mt 2015 Civic. About a month ago, my display said it was time to change my spark plugs. About 2 weeks ago, we had a crazy cold snap when it was below zero for several days. During the cold weather, the check engine light came on and it said something about an evap system malfunction. when the weather warmed up a little--still below freezing--the check enging light went off. Driving in the snow, having the car idling in parking lots, etc, I didn't pay attention to my gas mileage at the time. I went to autozone and checked the codes. it said I had an evap purge/flow issue. I bought some NGK Iridium plugs and changed them that day. Ever since, I'm getting about 28MPG. The plugs were gapped right. I swithced them out with the old plugs, and the milesge is still around 28MPG. Any idea what is causing the drop in gas mileage?
Old Mar 11, 2021
Re: Sudden drop in MPG
what mileage?
typically, o2 sensors on their way out would cause MPG drops
moving thread to proper location
Old Mar 11, 2021
Colin42's Avatar
Still have the evap code? That could be making it run extra rich compared to normal when you start it and it's trying to get up to temp
Old Mar 12, 2021
Webguy64's Avatar
PO497 EVAP Canister System Low Purge Flow
P145C EVAP Syestem Purge Flow Malfunction
PO496 EVAP System High Purge Flow Detected
The light came on when it was 15 below zero. The light has stayed off ever since. I figured maybe the vavle got stuck in the cold temperatures. When it got up to about 20 degrees, the light went off and is still off.
If the light is off, could it still be malfunctioning?
Old Mar 12, 2021
Webguy64's Avatar
Old Mar 12, 2021
Webguy64's Avatar
It has about 105,000 miles. But the drop in gas mileage was sudden. It was getting 35–39MPG, then immediately after the cold snap (when I only drove a total of about 20 miles) it started getting about 27–20MPG.
Old Mar 12, 2021
Webguy64's Avatar
The original plugs were gapped at about .005 when I removed them. The new NGK Iridiums I put in came out of the box at .042, but were supposed to be pregapped to .044. I adjusted them to .044 and my gas mileage immediately dropped to 27–28MPG. I regapped the origianl plugs to .044 and reinstalled them, and the MPG is still 27–28. I wonder if I should try opening the original plugs back to .005 and see it the mileage improives???? It's supposed to be .044.
Old Mar 12, 2021
reset codes with OBD reader if you have one.
if not,
get your radio code (not sure if 8th gen have them or not, but...)
disconnect battery for a while
this will reset computer
go from there.
corysam
General 8th & 9th Gen
Mar 26, 2020 07:58 AM
Hawgtired
Regular Maintenance
Nov 20, 2014 07:18 PM
ominousnimbus
47
Jun 25, 2014 07:02 PM
mikem317
Jun 16, 2007 11:48 AM
Boods
Aug 8, 2006 08:37 PM
