Coolant leak!!
Old Dec 31, 2020
wovenwarrior28's Avatar
wovenwarrior28 is an unknown quantity at this point
Coolant leak!!
Hey all!
I have a coolant leak shown here in my 06 civic. Not long ago I took off the engine coolant outlet flange and cleaned up and put sealant on either side of the gasket. However, the flange itself has a hairline crack in it on the inside towards the outlet port. Would the crack be causing the leak? I’ve ordered a new flange but I need this car for work on the daily. Has anyone else had a leak right there? What turned out to be the issue?
Thanks! (Spot is on the left side of the air box.)
Old Dec 31, 2020
Re: Coolant leak!!
see if you don't have this issue. That section collects the cracked block issue in the R18 engines. Also, Google R18 cracked block, choose images to see examples of cracks
I am not saying you have it, I am saying to check for them.
https://www.civicforums.com/forums/3...locations.html
Old Dec 31, 2020
Re: Coolant leak!!
I’ll get my mechanic to check but the leak appears on the side as opposed to the front or back of the block where the cracks tend to appear. To add more context it’s an 06 ex with 351,000 km. Aside from this leak it runs like a tap.
Tristinn Davis
Jul 26, 2020 08:44 PM
Rickyboy13
Interior
Dec 29, 2019 03:16 PM
brenden.bruce
Oct 30, 2013 11:38 PM
BombSquad91
Jul 16, 2011 02:04 AM
