Gas Mileage Issues / Check Engine Light
Old Oct 1, 2019
Tsanders8's Avatar
Tsanders8 is an unknown quantity at this point
I own a 2012 Honda Civic EX, which I use to commute 300 miles round trip, daily. I was getting about 40 MPG during my commute, but my MPG has dipped down to about 30-31. The check engine light also came on. I had the code read, and it showed the Civic was running too lean, with the likely problem being the mass air flow sensor. I replaced the mass air flow sensor, but am seeing no change. My check engine light will come on, but then disappear and I am still getting 30-31 MPG. Anyone experience this same issue, or have a solution? Anything is appreciated, and thanks in advance.
Tyler
Old Oct 1, 2019
GolNat's Avatar
Prelude Owner
Re: Gas Mileage Issues / Check Engine Light
Was it replaced with an OEM part?
Not sure when gas stations switch over to winter gas but that will drop MPG. Also a dirty O2 sensor (A/F sensor) will lower MPG.
ajohara68
Mar 4, 2016 08:33 PM
mililani
Jan 8, 2015 04:06 PM
teg91ls
Dec 10, 2005 06:23 PM
dru106
Jan 12, 2003 12:43 AM
xhl
Mar 18, 2002 05:44 PM
