2007 Civic No Start
Old Dec 29, 2018
john_b's Avatar
john_b is an unknown quantity at this point
2007 Civic No Start
Greetings friends. A customer towed his 2007 4door sedan Civic to my shop after someone hit his right fender. We repaired the broken fender and repair all the damage wires. Only to find out the car cranks well but no start with a flashing key light in the dash. Execute some diagnostics on the vehicle and found a few codes both current and temporary. P1659, P060A,P0606,P0498. Also ran a check on the immo because of the constant flashing green key in the dash,we have only one master key.Did the check and receive this error IMMOBILIZER SYSTEM IS NOT NORMAL. D3 NO COMMUNICATION BETWEEN ECM/PCM AND IMMOBILIZER UNIT. I checked all fuses and none was faulty,battery have sufficient charge, also test the immo wires for continuity to ground and power from the under dash fuse box and all is report to be ok. Any suggestion with regards to this problem.
Old Jan 1, 2019
mac25's Avatar
Dr Krieger of Modification
Re: 2007 Civic No Start
Old Jan 10, 2019
john_b's Avatar
Thanks mate, replace the ecu and reprogram the immo and vin and it started
Old Jan 11, 2019
mac25's Avatar
Good to hear it worked out.
thumbelina
Jun 12, 2019 08:42 AM
MAC2017
Jan 21, 2018 05:16 PM
buba1908
Oct 21, 2017 01:21 PM
hellobd
Apr 8, 2012 12:06 PM
sh3Ltz
Mar 18, 2009 09:53 PM
