2007 R18 Clicking relay no start
Old Aug 31, 2018
DSNW Toby's Avatar
DSNW Toby is an unknown quantity at this point
I have a 2007 Civic that I just installed a used engine into due to a cracked block in the original. After the car has sat for a few hours, I hear a relay in the engine bay clicking with the key turned to the ON position, and the engine will crank but not start. If I merely plug in an OBDII scanner, that stops the clicking. If I cycle the key OFF and then try a start, the engine will start and run fine every time. I have replaced the relays in the engine bay panel but the symptom persists. The scanner shows no codes or MIL indications. Could this be some sort of immobilizer issue because of the "new" engine, or something else? Any suggestions welcome.
Old Aug 31, 2018
Re: 2007 R18 Clicking relay no start
Missing ground, that one is located on the end of the head......Either the bolt is missing, it's loose, or you put in the wrong bolt.
Old Aug 31, 2018
DSNW Toby's Avatar
I poked around a bit and discovered that the ground bolt was missing. I installed a replacement, and all appears to be well. Thank you so much!
Old Aug 31, 2018
Amazing lol
dimartin
Mar 15, 2017 09:26 PM
Canboro
19
Sep 19, 2016 07:56 PM
kitchenguy
Aug 14, 2010 10:49 AM
ProDigy
15
Dec 15, 2002 03:09 PM
