2007 civic ex sedan with engine code p0420
So my check engine light came on the p0420 code came up, have had some small oil loss, but none of it was leaking on the ground. Driving the car home after getting the code read i experienced a severe lack of power(cruise control wouldn't keep speeds up if i was going up the smallest of inclines). Is there anything i can try to fix this myself? the car has 98k miles on it
Thank you for any help
Re: 2007 civic ex sedan with engine code p0420
P0420 is due to the computer not seeing correct readings from the secondary (downstream) O2 sensor. Have you already done the basic maintenance items like a new air filter and new spark plugs?
Xuhme
21
Aug 7, 2023 03:40 PM
Civicchicky87
Idle Issues
Apr 22, 2015 07:16 PM
