Engine Management Post information/questions about Engine Management, ECU, here.
Running lean:(
Old Jul 29, 2022
Jesse17301's Avatar
Jesse17301 is an unknown quantity at this point
Running lean:(
Hello so I have a 08 civic si with kseries fuel rail, stock injectors, Megan manifold, basic intake, walbro 255 fuel pump. I bought the car knowing it was running lean I replaced fuel sending unit and stock fuel pump and went to a 255 cuz that’s what I had laying around. That seemed to work for like 3-4 months no issues on a tune (in winter) then started to lean out again. In the beginning I could turn the car off and back on and that would fix it, now it’s doing it everyday. Afr is normal until 4,5k (vtech cracks) then shoots right up too 15-18. Just put a afr gauge in and also used Hondata app to make sure it wasn’t the sensor and everything matched between the two. Not really sure where to go from here. Any help would be greatly appreciated
Old Jul 29, 2022
Re: Running lean:(
get it to a tuner and check the programming
running lean is what destroys engines, a tuner is less expensive
Old Jul 29, 2022
Colin42's Avatar
Re: Running lean:(
Get a better tune
Old Jul 29, 2022
Jesse17301's Avatar
Re: Running lean:(
Originally Posted by Colin42
Get a better tune
tune is fine I ran it for at least 4 months and added a revision once it started leaning out and I have hondata too
Old Jul 29, 2022
Re: Running lean:(
again, take to a tuner.
They probably will be able to tell you if something else is causing the issue.
motekeeper
Sep 15, 2013 01:17 PM
TunersDesire
Bolt-on Engine Performance
Dec 6, 2012 12:05 AM
TransformedBG
Apr 7, 2006 08:33 PM
TransformedBG
Mar 25, 2006 12:58 AM
ripper
Jan 28, 2002 02:00 PM
