Dupli-Color Clear Top Coat?
Old Jun 20, 2003
wonderz's Avatar
wonderz is on a distinguished road
Question Dupli-Color Clear Top Coat?
Has anyone used dupli-color clear top coat? For some reason, everytime I used it to apply a top coat on a painted piece, the paint becomes all wrinkles and never smooth and it also makes the painted color look faded. Anyone know why?
Old Jun 20, 2003
Weaponx12o's Avatar
did you apply thick or light coats?
Old Jun 22, 2003
wonderz's Avatar
light coats
Old Jun 22, 2003
Weaponx12o's Avatar
make sure you're painting it in a cool environment. nothing over 80 degrees. or else it wont stick right to the piece
Old Jun 24, 2003
wonderz's Avatar
what i want to know is that why does it have those wrinkle effect?
Old Jul 1, 2003
Weaponx12o's Avatar
probably because of the heat. make sure when you're painting it, you paint in a cool place. it will start to bubble and wrinkle up if you paint when its hot.
Old Jul 15, 2003
orion_squall's Avatar
no man
the paint you have under is enamel, and the celar coat is laquar...you have to paint enamel on enamel. or enamel on laquar
Old Jul 15, 2003
can someone tell me what is a acrylic clear coat paint?
Old Jul 15, 2003
erica02civicCPE's Avatar
erica02civicCPE is an unknown quantity at this point
they have a bunch called "Plasti-Kote" try that....I know they have it at Pep Boys.
Old Jul 16, 2003
wonderz's Avatar
where can i find wheather the paint is enamel or laquar?
EDIT: if you don't paint the laquar Clear Top Coat on top of anything, why its call clear top coat?
Old Jul 16, 2003
that is the trick
if you are careful you will notice many of the clear coat says:" laquar, do not apply on enemel". and some clear coat is laquar, but they don't say "not to apply on enamel." BUt I would think is the same.
obviously, they expect to paint with laquar and clear coat with laquar.
you can always put laquar on enamel, with risk of wrikle, drip and effect of "lift" the original color. But if you are pro, nothing of these will happen as you will understand about coating window, coating kill etc.
SidCivic
Sep 12, 2015 05:28 PM
sccarally
Texas
Aug 21, 2015 10:09 PM
