the best way to get a dealer sticker off?
Old Mar 23, 2003
ponyboy's Avatar
ponyboy is an unknown quantity at this point
whats the best way of getting of those stupid dealer stickers? my friend said a blowdryer but seemed kind of dumb, but i dont know.
Old Mar 23, 2003
edicivic2k1's Avatar
edicivic2k1 is an unknown quantity at this point
I heated mine with a hair dryer, then, and very carefully, I used needle nose pliers to grab and pull that sticker off. It was like aluminum on top, then had like a sponge layer, then the sticky layer. So after I pulled off the aluminum layer there were 2 layers left, I just heated it up carefully with the hair dryer and bit by bit picked and rubbed the rest of the krap off. I may have used a chemical, like rubbing alcohol, but it eventually all came off. Then i waxed the area. There are no residual marks on the paint. So be careful, not careless.
Old Mar 23, 2003
Mbow's Avatar
I have always used my finger nail to lift and corner and then peel them off. Afterwards, I polish with Klasse all-in-one to remove the residue. WD-40 will remove any sticky stuff with ease as well.
Old Mar 23, 2003
GrayGhost's Avatar
Welcome To Prime Time, BITCH!
GrayGhost is on a distinguished road
Your friend was right. The best way to remove any sticker off a car without damaging the paint is to first heat it with a hair dryer. Then use your finger nails to peel the sticker off as you are heating it. Then after the sticker itself is removed use a type of adhesive remover to remove the reside from it.
Old Mar 23, 2003
GrayGhost's Avatar
I would not advice using pliers or any other such tool in the removal of stickers. You run the risk of scratching the paint if you do that.
Old Mar 23, 2003
Bartkat's Avatar
Don't use pliers. Take a piece of strong string or fishing line and run it behind the sticker. Then kinda with a sawing motion work the string back and forth and pull it so it cuts behind the sticker. This, of course after warming with a hair dryer. Use tar remover, or WD40 or even kerosene to remove the goo and then wax hell out of it.
Hair dryer and Wd40 also works good for removing pinstripes or any other decals or stickers.
Check the DIY section. I believe there is a DIY on shaving emblems.
Old Mar 23, 2003
ponyboy's Avatar
thanks, the hairdryer worked really well
Old Mar 24, 2003
InanimateCarbonRod's Avatar
InanimateCarbonRod will become famous soon enoughInanimateCarbonRod will become famous soon enough
I used soapy water. I applied it with a paper towel and lit it sit for about 15 minutes. The sticker peeled right off. A little cleanup work with adhesive remover, polish/wax, and I was done.
Old Mar 30, 2003
OyD's Avatar
OyD
OyD is an unknown quantity at this point
The hairdryer is probably the best way to do it.
A better way though(which you are past this point) is tell the dealer to not even put is on in the first place. When I told mine they asked why I didn't want it and I just told them if they wanted to pay me for advertising then they can put it on.
Old Apr 8, 2003
Cisco88's Avatar
Cisco88 is an unknown quantity at this point
If your at a Car wash with hand washers just put the gun up to the sticker, it will heat up the adhesive and just pull it off.
Old Apr 8, 2003
GrayGhost's Avatar
I'm not sure with the policies of other dealerships, but at the dealership that I work at we put the stickers on the cars before they even go on the lot. However, if requested, we will remove the sticker for a customer if they wish us to do so.
Old Apr 11, 2003
XTREME2K2CIVIC's Avatar
Reppin Stage 7
Use a product called Goof Off avail. at Home Depot...
Old Apr 24, 2003
FBIWannabe's Avatar
FBIWannabe is an unknown quantity at this point
is goo off safe for the car paint?
Old Apr 24, 2003
Bartkat's Avatar
Yeah, just be sure to clean it off when you are done, and put a coat of wax on the area where you used it.
Old Apr 28, 2003
SupaCivic's Avatar
SupaCivic is an unknown quantity at this point
is dis goof off thing good to take of decals too o jus liek dealer stickers... I really wanted to take of ma decals, i have ove on da rear window an da rest is on da paint... watz da best way to do it.. is it da blow dryier idea o anythin better.... wat if i took it to a body shop... tell me wat u guys think.... peace... p.s anybody in da chicago land area, come to da May 24th meet at busse forest perserve un schaumburg.... peace....
Old Apr 28, 2003
Bartkat's Avatar
Bug and tar remover works for decals and pin stripes. Just let it soak a little and then use the blow dryer to heat as up pull on the sticker. It took about 10 minutes to take off both my pin stirpes that way. Just pull kinda slow as the heat releases the plastic.
Old Apr 29, 2003
SupaCivic's Avatar
thank bro i'll try that...peace
Old Jul 17, 2003
civicstyle82's Avatar
civicstyle82 is a name known to allcivicstyle82 is a name known to allcivicstyle82 is a name known to allcivicstyle82 is a name known to allcivicstyle82 is a name known to allcivicstyle82 is a name known to allcivicstyle82 is a name known to allcivicstyle82 is a name known to all
i used a hair dryer and my fingers and it worked fine, got a little warm on the fingers every now and then, i also used this method to remove the stickers from the bottom corner of the windows.
solarpunk70
Apr 12, 2016 11:43 AM
brash99
Sep 29, 2015 08:42 AM
2002ExCivic
22
Sep 28, 2015 08:29 AM
260000milesgoal
Sep 25, 2015 07:41 PM
vImpostor
Vancouver
Sep 8, 2015 08:08 PM
