Cleaning interior
Cleaning interior
What do you guys use to clean the interior cause whe ni use a towel and water it leaves like towel lint all over??
e-married to daydreamer
meguiars all natual. i have a technique that bring out the interior real nice. otherwise yeah wipe away with some microfiber cloths. i dont know if you should dampen the cloths though
I use this stuff by Blue Coral that is pretty cheap if I remember correctly. You just spray it on the spot and let it sit for a minute it or so. Then, you just dab the spot and soak the cleaner up. I use a terry towel but don't really have any lint problems. After you wash them about 5 times the lint, at least the big pieces, seem to go away.
Ok guys how do I go about removing interior scratches? Like on the bottom of the doors and the center console?
If they arent deep scratches, and they are just shoe scuffs...you can use any type of polishing compound. I use 3m rubbing compound. I know it sounds crazy but we used to do it all the time at the car dealer I worked for. It works great. Just remember to dress the plastic after you wipe off the compound....because it may dull the color
dude,i took my baby blu to the washand those fools used some sh*t that like,messed up the paint around the window switches and other small areas w/ that metallic paint-damn-it loks like gooey gum or some ****?i dunno-t wont come off
Quote
[hr]Originally posted by: diegoblu
[hr]
[hr]
Quote
[hr]Originally posted by: BlkCivicAngel
Rule of thumb - if you care about your car - car washes are very bad - leaves tons of scratches from going through those machines and they dont care too much on what they do or dont scratch[hr]
Quote
[hr]
[hr]
Honda makes some cleaner that you can get from the dealership or at a Honda motorcycle dealership. It comes in a black and sort of pink can. It works great!! I use it for dang near everything. Panels and shoe scuffs comes right off. The dash cleans right up. Glass? Cleans right up. Wheels, dirt and grime? Cleans right up. I wash my civic about 2-3 times a weeka and I use it for virtually everything!! Its good stuff!! The only drawback to this stuff is that for the best results you need 2 rags if you are using it on your paint or shiny surfaces. It is somewhat greasy the first application when you r removing dirt and grime. But when u use that second rag to shine it up.......BLAM!!!
breanna_17
Jul 21, 2015 04:01 PM
LorenzoC0395
Jul 14, 2015 08:46 PM
Jul 12, 2015 11:54 AM
