removing
Old Aug 19, 2002
cable's Avatar
cable is an unknown quantity at this point
removing
if i have a scratch on my car and i can feel it with my fingernail, what's the best way to remove it?
if i do it myself, what's the best method?
if i get it done, how much should it cost around?
thanks!
Old Aug 19, 2002
n00dleboy's Avatar
n00dleboy is an unknown quantity at this point
Quote
[hr]Originally posted by: cable
thanks![hr]
If you do it by yourself do it with scratch X or something similar, then wax/polish it after.
If you get it done, it can go from 100-300 depending on where you take it (Canadian prices) as some bodyshots will paint the whole panel rather than just buffing it and repainting it. I'd suggest looking up Colorworks.ca
If you do a search in detailing you'd get more results.
Old Aug 19, 2002
touwseew's Avatar
touwseew is an unknown quantity at this point
scratch x works pretty well, but only on small scratches. touch up may work as well.
Old Aug 19, 2002
whowhatwhoa's Avatar
Eat poo & Choke ...I don't eat ham cuz my last name is HAM !!!!
From: Palisades Park/Rutherford, New Jersey/in ur CORNHOLE, US
whowhatwhoa is a jewel in the roughwhowhatwhoa is a jewel in the roughwhowhatwhoa is a jewel in the rough
i usually use 3M compound for small minor scratches
Old Aug 20, 2002
Mbow's Avatar
Yep, try the 3m swirl remover and go over and over the scratch till you get down to a very light scratch. Then, put some #7 glaze on it and wax. This assumes the scratch is in the clearcoat of course.
Old Aug 21, 2002
cable's Avatar
i think its still in the clearcoat...
but i can feel it with my fingernail...
does that matter?
thanks...i'll try it out...
Old Aug 21, 2002
Mbow's Avatar
As long as the bare medal isn't exposed you can make it look a lot better. I tend to not attempt getting rid of scratches completely as I am afraid of taking off too much clearcoat or getting down to the paint. You can use the 3m swirl remover to get it down to a light scratch. The #7 glaze and gold wax will pretty much hide the light stuff.
Old Aug 22, 2002
2Hottie's Avatar
2Hottie is an unknown quantity at this point
Also, if the scratch is deep and requires touch up, don't use the brush that comes with the touch up bottle..instead, use a very fine toothpick, dab on a very small amount of touch up on the tip of the toothpick and just put it on the scratch lightly..thicken up the coats to match the surround thickness of the paint & keep it level...
2Hottie
Old Aug 23, 2002
cable's Avatar
its a pretty long scratch though...its like someones shopping cart went against my car, but the metal isnt exposed.
thanks a lot though, i'll try it out.
Old Aug 24, 2002
2Hottie's Avatar
Yeah, if you can't see the metal, you are in better shape...if you can feel the scratch with your fingernail, it won't be easily removed by using waxes and stuff...
2Hottie
Old Aug 27, 2002
cable's Avatar
what do you recommend a good solution would be, if you can feel the scratch with your fingernail?
Damn HeadGasket
Aug 23, 2015 05:27 PM
herbiej
22
Aug 23, 2015 01:02 PM
WaryDriver
Aug 16, 2015 11:22 AM
greenbackz
Jul 30, 2015 12:04 AM
ballmich
Jul 9, 2015 11:59 AM
