Blurry Headlights
Old Jun 18, 2018
HammondT's Avatar
HammondT is an unknown quantity at this point
Blurry Headlights
Hi guys!
I could not find any DIY section so I hope posting here is fine!
I need you because I have to deal with the scourge of all headlights… BLURRY HEADLIGHTS!
I did not pay attention to my headlights and now they are all dirty, I tried cleaning them with toothpaste and a brush as a friend told me but it failed and I really have to get it done: It would be dangerous to drive without them being spotless… any tips? I am getting really desperate…
Also, if anyone knew how to protect my headlights so it does not happen again, I’d love them to share with me!
Old Jun 19, 2018
Wankenstein's Avatar
Re: Blurry Headlights
600 grit wet sand with light touch followed by a clear coat spray of polyurethane.
A less lasting option: any well reviewed commercial brand treatment.
If condensation is being formed inside headlight housing only a new or used replacement will fix it.
Old Jun 19, 2018
Colin42's Avatar
I use the meguiars kit and it works really well, not a permanent fix, been a year and they're starting to get foggy again. Think I'm going to clear coat them this time
Old Jun 19, 2018
mcnoople's Avatar
The legs in the public bathroom stall
mcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to behold
Most "cheap" clear coats don't last very well either.
I seem to recall a spray can of 2K clear coat available on the market. I think eastwood carried it, but likely available through other sources. The can was about $20 US and once "opened" it had a shelf life of 48 hours, but it was a proper hard strong clear instead of soft spray can clear coat.
That is what I am using when I redo the headlamp housings on the wifes MDX.
found it on amazon
Amazon Amazon
Old Jun 19, 2018
so many products around for that that i do not even know which to recommend
clear coat afterwards helps.
Old Jun 20, 2018
RobertD's Avatar
RobertD is a jewel in the roughRobertD is a jewel in the roughRobertD is a jewel in the rough
my aunts CRV:
i have been getting 4+ years out of using $5 clear lacquer spray paint from the hardware store. this is illinois, might be less somewhere like florida. krylon makes a clear with a UV blocker which i would expect to work good.
i just sand with 400 grit wet with a drop of dish soap, dry thouroughly, wipe with mineral spirits or similar, and spray on several coats of clear. i like to do a light misting followed by 3 wet coats. if you paint them on a humid day, the clear will have a white milky haze, so pick a non-humid day.
Old Nov 9, 2019
j1990's Avatar
j1990 is an unknown quantity at this point
+1 for meguiars
2002ExCivic
Apr 22, 2011 09:41 PM
Silver_Si
Dec 28, 2004 01:06 AM
HIGHLYreflective
Feb 14, 2003 02:14 PM
2001CIVICLX
Jan 27, 2003 07:27 PM
WishIWaitedForRSX
Jul 15, 2002 04:09 PM
