Fixing Fender Rust
Old May 11, 2012
pollycranopolis's Avatar
pollycranopolis is an unknown quantity at this point
Fixing Fender Rust
I have an 03' Civic EX 4dr. Noticing some rust spots beginning to creep up around the lip of my rear fender wells. Requesting advice on fixing them before they get out of hand. Picture links are below..
http://dl.dropbox.com/u/9599131/IMG_1405.JPG
http://dl.dropbox.com/u/9599131/IMG_1404.JPG
http://dl.dropbox.com/u/9599131/IMG_1403.JPG
My initial thoughts were to do this:
1. Use a dremel tool with sanding disk and blast down the affected areas to bare metal (including the bottom lip of the fender).
2. Tape off the area and spray the areas with some primer (what kind of primer?)
3. Apply some sort of matching car paint spray (which kind of spray?)
*Keep in mind I'm not looking for a perfect factory finish. I would like to find some spray paint with some gloss close enough to the black color to blend in reasonably well, but getting a finish exactly like the factory clear coat is not a priority as the areas are relatively small.
Old May 27, 2012
amphiron's Avatar
amphiron is an unknown quantity at this point
Re: Fixing Fender Rust
Also have the same problem on my 99 EX http://i24.photobucket.com/albums/c4...527_164854.jpg
I'm pretty sure you need to use a spray gun with the OEM paint and then wetsand to match.
Any civic specific write up would be great
usajags84
15
Aug 19, 2015 03:12 AM
wcodyd
Exterior
Jun 22, 2015 11:24 PM
Death.by.low.
Jun 14, 2015 06:31 PM
Mercilus
Jun 7, 2015 10:00 PM
Blazz
Jun 4, 2015 01:04 AM
