removing primer
Old Apr 13, 2002
Vicci4Life's Avatar
Vicci4Life is an unknown quantity at this point
removing primer
Alright peeps, hows it going? not too great for me, about 6 months ago someone tried to jack my car, they ruined the passenger door but didn't get in. So, I took it to this place to have it fixed, the messed up the paint job, brought it back- said, do it right- used the wrong color this time, brought it back again and its still messed up, but anyhow, this last time they left paint primer and the passenger side exterior door handle! I was pissed, but I know I'm not going to bring it back there, it was a horrible experience. Is there anyway I can get that primer off the handle, or how to repaint it or something? thanks guys-
Old Apr 14, 2002
pr0ph37's Avatar
pr0ph37 is an unknown quantity at this point
is it just the handel? if so try taking the door handel off(not shure how but im shure thers a post or some one knows) then you can take that back and be like you guys are idiots paint my handel. if you want to sand i posted a topick asking about that in the teck forms yesterday. IamLoki said
<< Use a block sander or a dual action sander and 320 grit. follow up eith 400 by hand. >>
however this is for a 69 mustang all heavey sheet meadle. if you want to see the post just search 'sanding' hop that helps
Old May 23, 2002
darkside420's Avatar
darkside420 is an unknown quantity at this point
my suggestion would be to use rubbing compound or clay bar wax.. That stuff takes paint and other crap off your car. Clay bar worked great on my work van it took a black mirror mark that was about 2" high and 3ft long on white van. The mirror left like a rubber/paint material behind that wouldn't wash off! U Could try like a wet sand with 3000 paper too but be care with sandpaper!!
l8r
darkside
Old May 23, 2002
JSWhaler's Avatar
JSWhaler is an unknown quantity at this point
you don't want to put wax on it cause that will just add a layer of protectant on it, will do nothing for removing the stuff. As for the clay bar you could try it, but it probably won't do much. My best advice is to go back and make them do it right, if not then take this matter up with your insurance company so they have to deal with the problem. As long as this matter was taken up with your insurance company, its partially their job to help you out, make em do their work. If you take off your door handle more things could go wrong. Good luck
Old May 23, 2002
civicdude's Avatar
Try the clay bar, it should work. If not try a solvent like Aftaline. You can buy it at homedepot.
herbiej
22
Aug 23, 2015 01:02 PM
WaryDriver
Aug 16, 2015 11:22 AM
greenbackz
Jul 30, 2015 12:04 AM
ZILLA
Air Conditioning
Jul 11, 2015 08:35 PM
ballmich
Jul 9, 2015 11:59 AM
