Purple Power
Okay, I'm a bit lsot here, I've never done this before and I don't know anything about being in a forum. Well, whatever. I was wondering if anyone knows what purple power can do to glass. I had this horrible white film on my windshield (outside) so I went ot the auto parts store and the guy there, used pirple power, but when I read the bottle, it said not to use on glass. Now I'm nervous that my winshield will be messed up...The good news is that I can actually see out of it now. Let me know if anyone knows anything about this.
thanks,
SunnyD.
thanks,
SunnyD.
Original Formula: high tech reusable concentrate liquid pipe cleaner for use on pyrex, glass, acrylics & ceramics that has been trusted by millions as the industry standard and far exceeding all others for over 6 years. Purple Power Original is a twenty minute soaking cleaner that may be reused numerous times without loss of effectiveness, however it should not be used on metals.
if it is a degreaser than it might ruin the tint and oils on your windshield.
however, if the oils were thick enough to merit using a degreaser, then it might just be enough to get rid of it.
lets just hope that guy didn't pick the wrong bottle...
Thanks. I suppose if it were going to ruin it, it would have by now. i don't have tinted windows so I'm not worried about that. I have another silly question, how often should I replace my wipers?
You can clay bar the windows if your trying to get crap off of them. And with the wipers, it depends on how often you use them, sometimes not using them is harder on them because the rubber dries out, and if you think you need it. If you use them on an icy windshield, you pretty well need to get new ones.
the moment it starts squeeking/after a lot of snow/salt/anything that could get caught on the wiper blades.
you get a free set of blades if you go to the stealership for oil changes, so I suggest every time you change your oil (if you don't go to the stealership).
Originally Posted by sunnyD
thank you. Obviously I know nothing about cars, so I figure this would be a place to ask.
yeah dont use degreaser on your windows...if you windows are that bad you can try a mixture of 1/2 rubbing alcohol and 1/2 water..that will take care of.and when it comes to chemicals of any kind..be it to clean you car or to maintain it, always follow the manufacturer directions
BootyDo
Jul 26, 2015 10:38 AM
Dave1984
Jul 22, 2015 06:10 PM
breanna_17
Jul 21, 2015 04:01 PM
