Swirl Removal
Swirl Removal
I use Meguires 3 Step and it works good, but since the Paint Cleaner Step has chemicals in it that can strip clear coat,, is it bad to Use it to much? It says put it on and whip it off dont let it dry.
Check out the stickies in this forum: http://www.danase.com/forums/viewforum.php?f=4
Swirl removers just fill in the swirls once it rains walla they are back. I used to detail for mercedes and bmw and the dark cars were a b!tch to get swirls out. Best thing to do is compound, then glaze, then polish. Its a long process but its worth it. If you have a really good buffing machine your all set. If not, get that elbow grease going but the job wont be as good as a buffer.
The Deep Crystal Paint Cleaner does remove clear, but is sooo microscopic you would be shortening the life of the clear dramatically. I only recommend applying it when neccessary. You don't need to apply all 3 steps everytime. Paint cleaner do not fill in scratches they remove them. Polishes would more likely hide/fill them.
LOL I don't ever like coming off like a jerk but I get sick of reading false info. all the time that will just confuse people more and have them doing un-needed steps or steps that will cancle out the previous one.
Clearkote...have you been to the forums latley? They will be here by the end of the week.
Damn HeadGasket
Aug 23, 2015 05:27 PM
WaryDriver
Aug 16, 2015 11:22 AM
greenbackz
Jul 30, 2015 12:04 AM
ballmich
Jul 9, 2015 11:59 AM
