Cleaning between the rear window/brake light?
Hey, it didn't show up...
Thread:
Does anyone know how to clean between the rear window and the rear brake light? It's in the bottom center of the rear window. My hand doesn't fit in between the glass and plastic, so I can never clean that area.
Would I have to go to a auto detailing shop just to get that spot clean?
Thread:
Welcome To Prime Time, BITCH!
There is really no easy way to clean this area. The best way is to remove the rear deck and clean the window. Otherwise try using a ruler or something similar to push a cloth into the area to clean.
Just unscrew?
I need TP for my bunghole
get some old socks
windex
and a ruler
spray windex on the sock and floss between the light and window.
if that does work insert the ruler into the sock and clean it that way.
windex
and a ruler
Removing the deck is in the DIY:
http://www.7thgencivic.com/modules.p...howpage&pid=54
I haven't gotten around to cleaning in between the rear windshield and brake light yet. I noticed that crap has been building up from everytime I spray my window cleaner back there. A little bit of spray ends up in between the light and window, and after the years, I've got quite a build up.
I was going to remove the rear deck when I meant to buy some new 6x9's, but priorities changed, and I got sway bars and coil-overs instead.
Balut Eating Champ
Originally posted by MeguiarsEM
Anyone have the removal directions for the rear deck lid?
here's how:
-take the backseat off, refer to DIY
-take the upper rear corner plastics off (on the roof)
-unbolt the driver and passenger seatbelt metal bars
-yank out the walls (screw on the handle covered by a small plastic cover)
-take off read rear deck lid (unhook the brake light wire)
Blaster30
Apr 22, 2015 12:21 PM
