clay bar...sucks or do i need practice?
Old Mar 18, 2004
EnProceso's Avatar
after everyone here saying how awesome the clay bar is i bought one and gave it a try. i got meguairs detailing package (clay bay and detail spray). the box said to wash the car first then dry it, the spray some of the detailer spray then wipe it with the clay bar. thats what i did but it left hella sticky smears on my car! i only wiped where the spray was so it was lubricated but it would still stick and smear, i was hella pissed off!! it took f*cking forever to get those marks off! was i doing something wrong, what should i do? i seriously doubt i'll use this again unless i get some tips on how to avoid this whole mess cuz for right now, IMO clay bars suck!
Old Mar 18, 2004
sKwiD's Avatar
I Queef > You
sKwiD is on a distinguished road
umm, I think its just you man. I don't think you sprayed enough detailer on your car, which is why the clay left smears. I mean by using a clay bar, you're taking EVERYTHING off of your clearcoat, including dirt, contaminants, and even wax. Thats why you should wash your car again, then wax it after you finish clay barring. Guess you just have to be patient when detailing. I dunno man.
Old Mar 18, 2004
rckdrmr's Avatar
rckdrmr is on a distinguished road
you definitely did it wrong when you smeared the clay onto the finish. you don't have to apply much pressure at all to use it correctly, just spray a good amount of quik detailer (on the clay as well) and then glide the clay up & down until you notice that the contaminants, black dots, dirt, etc... is off the finish (pretend like your lightly sanding). practice makes perfect and keep trying until you get it down, i've done it several times and have had no problem. if the clay is obviously smearing onto the finish... your not spraying enough quik detailer and or applying too much pressure. good luck!
Old Mar 18, 2004
guamcivic2k1's Avatar
YoUnG N SuXsExFul
i didn't use the lube..and i didn't get any smears...maybe u wre pressing it to hard..
Old Mar 18, 2004
EnProceso's Avatar
i was just "running" it along the paint, i wasnt putting any elbow grease into it. i sprayed the bar too and it would smear less but still smear none the less. i was doing it in circular motions and it would slide smooth and just out of nowhere just "stick" in a spot and leave a mark. i dunno, i thought i was putting more than enough detalier spray (used up about a half a bottle on just the hood, roof, trunk) but maybe i'll try it again but if it smears just once, i'm tossing that bar in the garbage.
Old Mar 18, 2004
sspem2's Avatar
em2
u suk. i was the person who said the clay bar is awesome. didnt leave no marks on my car just a clean surface.
Old Mar 19, 2004
VTECTypeR's Avatar
once it sticks stop using the clay your done. I just wax over it and it comes out perfect.
Old Mar 19, 2004
MeguiarsEM's Avatar
MeguiarsEM is an unknown quantity at this point
Sounds right.
Originally posted by rckdrmr
you definitely did it wrong when you smeared the clay onto the finish. you don't have to apply that much pressure at all to use it correctly, just spray a good amount of quik detailer (on the clay as well) and then glide the clay up & down until you notice that the contaminants, black dots, dirt, etc... is off the finish (pretend like your lightly sanding). practice makes perfect and keep trying until you get it down, i've done it several times and have had no problem. if the clay is obviously smearing onto the finish... your not spraying enough quik detailer and or applying too much pressure. good luck!
Old Mar 21, 2004
AR's Avatar
AR
e-married to daydreamer
wash car 1st and dont dry it... let it rinse
then...
spray a small area of your car really well
take the bar and glide it gently over your cars surface that was sprayed
then take a 100% cotton terry and remover watery/spray leftover on your paint
when youre done with the entire car, wash the car again and dry it good. then youre ready to clean/polish/wax it.
Old Mar 22, 2004
bobbyd's Avatar
bobbyd is an unknown quantity at this point
I am a professional detailer and I tried Mequiars clay once and it took me longer to get the smeared clay off than it did to polish the car! If you want to go with a local store for clay go with Mothers.
Old Apr 3, 2004
EnProceso's Avatar
then...
ding ding ding! using the quik detailer sucks when using the clay bar, i just didnt dry the car and used the beaded water and it actually worked perfect! looks like theres some hope for the clay bar after all. thanks for the help
Old Apr 3, 2004
abmerop18's Avatar
Jam out with your clam out.
so, whats the best way to do this now?
Old May 10, 2004
sihotan's Avatar
sihotan is an unknown quantity at this point
get Mothers Clay Bar, works way better
Old May 11, 2004
rckdrmr's Avatar
there's also.... www.clay-magic.com
Old May 20, 2004
bobbyd's Avatar
If you got Meguiar's then it is the clay bars fault not yours. If you must buy localy I would use Mothers or Clay Magic. Will blow Mequiars' junk away.
Old May 20, 2004
I've heard that claymagic makes the best. I tried mothers and it wasn't working, so I just gave up for now.
Old May 20, 2004
alienmeatsack's Avatar
alienmeatsack has a spectacular aura aboutalienmeatsack has a spectacular aura about
I love my Zaino clay bar. It really helps get bugs residue and crap off the car.
GolNat
Nov 27, 2018 03:32 PM
solarpunk70
Apr 12, 2016 11:43 AM
Inkubus
Wheels and Tires
Aug 13, 2015 05:01 PM
