2001 civic 4dr door guards
Old Feb 17, 2004
lex990's Avatar
lex990 is an unknown quantity at this point
Ok,
Are these guards just stuck on with 2 way adhesive or are they actually bolted on? If you yank them off are the doors flush and no groves were they were?? I was told on my 94 ranger that the emblems were just stuck on and i didn't check on it and just ripped them off and they had 3 holes behind them i had to shave. so let me know about these guards so i don't have any surprises this time so my question is can you use a heat gun and just pull them off?
Old Feb 18, 2004
rckdrmr's Avatar
rckdrmr is on a distinguished road
Re: 2001 civic 4dr door guards
Originally posted by lex990
Ok,
if your talking about the door guard (no the plastic ones on the edge of the door) that go along in the middle on the side of the door.... i believe those are mounted/bolted along with adhesive tape. don't yank or pull it off, because it might take off some paint. not to mention... there will probably be a deep groove where the door guard use to be. if you take it off, you'll probably have to fill in/shave the holes/grooves and re-paint it. it's probably not worth the hassle. lease:
Old Feb 18, 2004
There's no hassle. I just ripped mine out on a warm day. It's just some glue in there. If it leaves marks on the outside, just clean it with Meguiar's clear coat body scrub. Mine turned out fine.
Old Feb 18, 2004
FALKEN's Avatar
Civicforums Junkie
the side moldings on the 4drs are attached by 3M double-sided tape AND plastics clips...so if you do take them off, you will need to have the holes filled and painted...not worth it in my opinion
note: only the coupes are attached with 3M double-sided tape (no clips) since the side moldings are an option and not standard equipment
Old Feb 18, 2004
He's talking about the door edge guards that go around each door to protect from dings and stuff, not side moulding...
Old Feb 19, 2004
FALKEN's Avatar
Civicforums Junkie
i believe that he is talking about the moldings
read the post again...he asked if they were possibly 'bolted on'
Old Feb 19, 2004
Okay, you're right. He says door guards but means side moulding But yeah, like Falken says they will leave holes if taken off.
TXcivic2001ex
Air Conditioning
23
Jul 20, 2020 07:27 AM
civic_gt
Apr 19, 2015 08:15 AM
CapYoda
Nov 11, 2001 05:17 PM
lilbluecivic
Nov 7, 2001 06:49 PM
liljoe
Nov 4, 2001 01:27 PM
