1.7 non vtech engine in vtech car.
Well I’ll start off by saying the car is a beater, low budget in mind. I have an 02 1.7 vtech 5 speed car and spun a rod bearing, and I have a parts car which is an 02 5 speed 1.7 non vtech. I’d prefer to keep vtech and have no issue changing head and gaskets. I read somewhere they have different compression and oil slingers. What besides the head would need to be done to change the non vtech motor to vtech while both engines are out? Thanks.
Re: 1.7 non vtech engine in vtech car.
Get a new oem headgasket, clean up the vtec head off the blown engine and slap that onto the non-vtec engine.
most of the time people ask about taking a non vtec car and installing vtec...your situation should be simple since you already have the wiring and ecu for vtec.
If it chewed up a bottom bearing, there's probably metal all throughout the entire engine, including up in the heads oil passages, cam and valvetrain.....to set vtec codes, and waiting for the worst possible time to cause even more damage
Replace the complete engine with a correct unit!
-vtec head
-solenoid
-wiring to the ecu from vtec solenoid
-vtec ecu
-reflash for your key to start the new ecu
You then may get a CEL for emission system errors since the non vtec system uses an exhaust manifold in place of a header and the O2 sensors are in diferent spots... but it should run. You'll probably also lose power if you don't run the vtec header.
so...
-vtec header or aftermarket larger header.
-vtec exhaust system.
-you may also need to extend one of the O2 sensor wires
-solenoid
-vtec ecu
so...
You might want to take the vtec head to a machine shop to do a pressure check and to clean it up for you. If it's good, obviously use it. If not, get another one. These engines and parts are easily found at your local pic-n-pull yard or on ebay.
oldbeatedhonda
Sep 13, 2014 09:15 AM
vic_325
Engine Swaps
Feb 23, 2012 06:56 PM
TheNaranjoExp
May 8, 2011 09:12 PM
MONTREALCIVIC
Feb 22, 2004 02:42 PM
