Transmission swap post information/Questions about automatic to Manual Transmission swaps
bought 5 spd from picknpull
Old Mar 29, 2023
civictrio's Avatar
civictrio is an unknown quantity at this point
It came out of an lx or hx and i ended up using sawzall to get the lines off that day. When i put it in the garage trying to get the two cotter pins off the transmission i kept using vice grips and there's barely anything left as it kept breaking pieces off, i got like 1/8 inch left of one side and used rust penetrator. About the only idea i have to get them off is a drill with that size drill bit or smaller but it'll probably just break. I'm not really sure how to get it off. Could i swap the whole pieces under it thats actually connected to the transmission? I have a vtech that needs tranny since 5th gear pops out right after its put in. before i replaced the clutch i could hold it in with my hand but not anymore. The cotter pins were a lot easier to get out of mine though
Old Mar 30, 2023
Colin42's Avatar
Re: bought 5 spd from picknpull
You can swap the shifter. The car wont feel as peppy though because you're putting in a nonvtec trans, some of the gears are different
Old Mar 30, 2023
VTEC (EX model) have shorter final?
Doing shifter/cables maintenance seemed to have solved some of the pops out of gear issues
Old Mar 30, 2023
BrotatoChip's Avatar
Super Moderator
Cut the cotter pin off flush with the stud. Try using a small punch and a hammer to pound it out.
But yes, gear ratios will be different. LX has a longer FD than the EX, HX has an even longer FD. I don't think that would cause any performance issues but I'm not entirely sure.
HondaRacer93
Sep 4, 2018 08:19 PM
StealyDan
Mar 5, 2018 01:44 PM
dsuhmibt1987
Jul 15, 2017 11:14 PM
GibaD17
Engine Swaps
Feb 1, 2007 11:23 AM
01hx5
Nov 22, 2005 07:52 AM
