Transmission swap post information/Questions about automatic to Manual Transmission swaps
Compatible Transmissions?
Old Aug 7, 2020
redrocket87's Avatar
Huckin' Hippie
redrocket87 is an unknown quantity at this point
I currently have a 2005 Civic Si-G with a 5-spd Manual, It sounds like my Input Bearing is done. I have another 7th Gen 2003 Civic DX with a 5-spd Manual and from what I can research the two are different slightly in the gear ratios ( the DX's rev's about 500rpm lower ),but are compatible for a swap. If this is true then the DX tranny has a lot less kms on it and no issues when it was parked. Can anyone verify that the 2 are interchangeable?
Old Aug 7, 2020
Colin42's Avatar
Re: Compatible Transmissions?
Canadian SI with a d17?
if so yes
Old Aug 11, 2020
Huckin' Hippie
It is a D17A2 in the my Si, so then it should bolt right up? I figure once I get the trans out of of the DX I'll pull the fill and the drain plug and flush the oil, I have to use Honda's specific manual trans oil correct?
Old Aug 11, 2020
Colin42's Avatar
Yep bolt right up no issues, I went the other way with my old car. And yes only Honda manual fluid
Firescooby
15
Feb 1, 2012 10:06 AM
Dizz
May 9, 2011 03:53 AM
jUiCeR.4
Sep 22, 2008 11:25 PM
Jasdip
Nov 24, 2006 09:18 PM
CivicManDan2
Sep 7, 2002 07:24 PM
