Turbo Post information/questions about Turbo here!
Turbo Timer problem
Old Apr 4, 2003
pon's Avatar
pon
pon is an unknown quantity at this point
Turbo Timer problem
need help
i installed my turbo timer and my alarm dont arm when the timer is counting down
so what do i need to do to make it work normally?
Old Apr 6, 2003
riceburnrex's Avatar
First to spool
riceburnrex has disabled reputation
There are many ways to do this....
one way... hook up the ignition wires from the alarm system so that it will not see that the car is still running (complicated), but if you have a sensitive impact sensor, the motor vibration will set it off
another way... get an alarm system that has a built in turbo timer or features to accomodate a turbo timer. CodeAlarm and Clifford both have these.
Some audio shops have had some success wiring a turbo timer and alarm to work properly, but I have heard that they are not as reliable.
Old Apr 7, 2003
reytito's Avatar
whats turbo got to do with alarm? i'm a newb to turbo...someone explain?
Old Apr 8, 2003
Boosted2k2's Avatar
Boosted2k2 should not be trustedBoosted2k2 should not be trusted
If you have a turbo timer, it allows you to leave your car running for a period of time after you take the key out of the ignition. It does it so you can cool the turbo down slowly. The problem is that he can't activate the alarm while the car is running.
Old Apr 10, 2003
iamboo's Avatar
Retired - SoCal FI Mod
you can always get one of those auto armming alarms... so right after the turbo timer does it's thing, it just arms the car
cbalonon
Turbo
15
Dec 1, 2015 03:22 PM
Tommy Cohen
Jun 14, 2015 10:36 PM
Supramk3
Jun 11, 2015 11:13 AM
sccarally
Texas
May 17, 2015 10:11 PM
mikevtec
May 3, 2015 01:36 PM
