Engine Management Post information/questions about Engine Management here! It's especially important for Forced Induction (Turbo and SuperCharging) and Engine swaps! What destroys engines are fuel management!
New AEM Piggyback (Seems VERY promising)
Old Jun 14, 2007
  #61
drew22mader's Avatar
There is gl@ss in my @SS...
Re: New AEM Piggyback (Seems VERY promising)
Damn man, this thing is awesome, and the partial throttle response that has caused so much trouble seems to go away.
Also found this little note.
Modern ECU's stay in closed loop at partial throttle and that can cause the problem you are noting. This is also present on turbocharged cars at very light boost on the highway. The factory tries to control to 14.7:1 AFR but the engine is under pressure so it should be run richer. Simply adding fuel wont work as the closed loop feedback from the O2 sensor will remove the fuel and store the correction in it's long term trims. Basically, the newer the car, the bigger the problem as threy stay in feedback under higher and higher loads.
The F/IC has the ability to Skew the O2 sensors. We dont intercept them, we tap into them and bias the signal to force the ecu to add (or remove) fuel. Since this allows the engine to still operate in closed loop, you are having the ECU do the work for you. The ECU increases the pulsewidth to add the fuel itself.
Old Jun 15, 2007
  #62
02BLKCIVIC's Avatar
Official Rattlesnake Hunter
Wo^ how did you get one???^
Old Jun 15, 2007
  #63
DelSolid's Avatar
DelSolid is an unknown quantity at this point
An updated F/IC wiring diagram for the 7th gen has been posted on the AEM forum. A resistor has been added inline with the O2 sensor for better AFR spoofing.
http://forum.aempower.com/forum/inde...c,20029.0.html
Old Jun 15, 2007
  #64
That's what i just posted lol on page 4. lol good looking out though DelSolid
Old Jun 15, 2007
  #65
DelSolid's Avatar
no, the one you posted is the old one. the new one has a 20K resistor in the O2 signal line.
Old Jun 15, 2007
  #66
ah ok, i just got it yesterday and i wasn't aware they updated since yesterday, good looking out!!!
Old Jun 15, 2007
  #67
Eyger's Avatar
A long winded 7th genr
Eyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond repute
This is all very exciting stuff. I'm really glad AEM is out there keepin it real!
Yo Dezod,
Are you thinking about offering this in your kit instead of the standalone EMS?
Old Jun 15, 2007
  #68
i'm sure it will just be another option on the drop down menu for EMS's in the S1 kit. the S2 kit is big dawg kit and runs the AEM Standalone.
Old Jun 15, 2007
  #69
DelSolid's Avatar
I had just posted the new one when I saw the your post here with the old one not 5 minutes earlier.
Old Jun 18, 2007
  #70
When will the plug and play be available to us? I want to pick that up and get this thing. Just Need my Race Manifold and the AEM F/IC and i'm good to go.
Old Jun 18, 2007
  #71
w00t! pNp harness is now available!
Old Jun 18, 2007
  #72
exturbo6's Avatar
lol nice drew, u want a cookie.
Old Jun 20, 2007
  #73
dezod's Avatar
7thgen Power Maker
Yeah Drew. EL manis are being worked on as I type this.
Old Jun 20, 2007
  #74
03-Acura-1.7-EL's Avatar
03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light
Red face Re: New AEM Piggyback (Seems VERY promising)
For d17a2? Where?
Cant see none at either Dezod nor at AEM.
Old Jun 20, 2007
  #75
go to boomslang's website.. they got it there.. i was thinking the same thing (about going to dezod's site) when i saw the PnP harness, then i remembered about boomslang.. its $209 shipped
Old Jun 24, 2007
  #76
geeno53's Avatar
geeno53 is an unknown quantity at this point
im about to turbo my d17...making sure to get this right...i will need the unit and the harness to hook to my 02 civic??
Old Jun 24, 2007
  #77
civic-driver's Avatar
civic-driver has a reputation beyond reputecivic-driver has a reputation beyond reputecivic-driver has a reputation beyond reputecivic-driver has a reputation beyond reputecivic-driver has a reputation beyond reputecivic-driver has a reputation beyond reputecivic-driver has a reputation beyond reputecivic-driver has a reputation beyond reputecivic-driver has a reputation beyond reputecivic-driver has a reputation beyond reputecivic-driver has a reputation beyond repute
if you guys havent found somewhere to buys these at JRPonline has them just an fyi
Old Jun 24, 2007
  #78
cheapest place i found it is at jegs.. and last i saw, they still offer free shipping.. it's 409 at dezod and 397.99 at jegs
http://www.jegs.com/webapp/wcs/store...0002_874633_-1
Old Jun 24, 2007
  #79
dezod's Avatar
7thgen Power Maker
it's 409 at dezod
Remember, you get $10 off for ordering online.
Old Jun 25, 2007
  #80
geeno53's Avatar
does jegs sell the harness that is needed or will i have to get that separately
Old Jun 25, 2007
  #81
you will have to either order it from boomslang or dezod.
Old Jun 25, 2007
  #82
speedfoos's Avatar
Buy it from Dezod. If you sweet talk Paul, he may throw in a Dezod sticker.....
Old Jun 25, 2007
  #83
Def buy from Dezod, support your sponsors on here guys.
Old Jun 28, 2007
  #84
Eyger's Avatar
^yeah bump for that!
Old Jul 8, 2007
  #85
dezod's Avatar
7thgen Power Maker
Well we have some F/ICs coming into stock. We have been blowing threw these things like crazy....
Old Jul 17, 2007
  #86
Can you plug the AEM UEGO into the AEM F/IC and log the A/F on to the computer?
Old Jul 17, 2007
  #87
dezod's Avatar
7thgen Power Maker
No sir. Not yet. AEM is working on some stuff like that.
Old Jul 17, 2007
  #88
andyman97's Avatar
Turbo Guru
Really? You can't datalog afr's with it? Good info to know...
Old Jul 17, 2007
  #89
dezod's Avatar
7thgen Power Maker
Supposedly all of the hardware is in place, but they need to make some software changes to get the logging aspect.
Old Jul 17, 2007
  #90
andyman97's Avatar
Turbo Guru
That's a shock to hear. I figured that would have been a major selling point. That's a necessity when tuning, unless you want to use a dyno's probe a/f sensor or the tuner has an FJO or something similar.
