Engine building Post information/questions about Engine Building here!
D15b with d17a2 head?
Old Jul 26, 2020
Em2boosted's Avatar
Em2boosted is an unknown quantity at this point
I recently bought and installed my engine and now ready to boost it. It has a block stamp of d15b and the head has a stamp ple7! Everywhere I searched says it’s not possible but I can prove it and it runs just fine. My question is that is it possible? And also what gaskets should I use to rebuild for the turbo?
Old Jul 26, 2020
FRSam's Avatar
Click Here
Re: D15b with d17a2 head?
I'm not exactly sure how it works, but there's a D15B that looks identical to the D17. You obviously have one of those.
OEM gaskets will be fine. You won't be running enough power for it to be an issue.
Old Jul 26, 2020
Em2boosted's Avatar
So that’s where it gets interesting, I basically plugged and played with the original d17a2 car, ecu and all! I would love to know what the engine is from because I can’t find it anywhere. It has d15b stamp and the head is for sure d17 because of the 5 bolt pattern for the exhaust. Also it is not the three stage vtec as the engine came with one solenoid. Just confused where to go with this engine. Obd2 setup with obd1 engine?
Old Jul 26, 2020
FRSam's Avatar
Click Here
Definitely still OBD2. Anything D17 was offered between 2001 and 2005. I'm guessing it's some economical JDM variant but I would be interested to know more. Any time I find one on eBay, it just says it's for 2001-2005 civics, so I'm guessing Honda just released these as replacement engines?
Edit: Not sure if this D15B block is the same as the old ones, but you can get a pretty gnarly Vitara setup on them for cheap, and they've made upwards of 400hp (they've made over 500, but not cheaply).
Old Jul 26, 2020
Em2boosted's Avatar
That’s what I’m after and even speaking with Honda techs that’s been doing it for years they have no idea what engine combination I have, it’s just weird but looks like I will have to order lower end parts for the d15 and top end for the d17. 🤷‍♂️ I have a turbo setup ready to go and looking for 400+ hp and I know with around 800$ I can have a lower end to put up with that hp gain
Bustitsideways
Aug 1, 2011 07:40 AM
Tomster25260
Aug 7, 2010 12:52 PM
sollow
Aug 17, 2008 04:32 AM
ST8RACE
Engine Swaps
Jan 30, 2007 10:33 AM
jaydm21
Nov 7, 2005 04:31 PM
