2020 EX CVT Tune question
Looking at Ktuner for a 2020 EX CVT stock. What kind of horsepower or 0-60 times could I expect. I see the boost numbers for the different stages but that is all I have been able to find. Most of the info I find is for the SI or manual.
Re: 2020 EX CVT Tune question
Ktuner with the 21psi tune will put you at around 215 hp. Kinda hard to dyno the cvt, but that's approximate power out of it.
I can tell you that a sport hatch CVT with a 21psi tune is a bit faster than a stock si coupe. I haven't checked my 0-60 time, but it pulls like a fiend, especially with the quick adjusts (like improved throttle response and turbo ramp up), and the fact that the cvt keeps you in peak torque band, for the most part.
Definitely wakes the car up and makes it even more fun to drive. Still get good fuel economy, depending on how you are with the throttle. About 50 miles on my current tank and average fuel economy meter is sitting at around 38mpg all city driving. Then again, I've been easier on this tank. I usually average 30-32mpg per tank
MTL2LO
Mar 29, 2006 11:43 PM
