Interior Post about Interior parts, seats, consoles, etc
Interior Door Lock Indicator?
Old Apr 4, 2024
Skylo's Avatar
Skylo is an unknown quantity at this point
Hey yall once again lookin for some help/insight/knowledge.
The interior switches that manually lock and unlock the car, specifically the passenger one is broken. The lock indicator that goes up and down is broken on the plastic tab behind the door card where it like, lodges into a lil metal bracket. What might I look up to order a replacement part/what could I do to replace it. I haven't taken an in depth look at it but it didn't look like a simple unbolt and replace so I'm seein what the consensus is here first.
specifically the little white plastic thing is broken.
Old Apr 4, 2024
BrotatoChip's Avatar
Super Moderator
Re: Interior Door Lock Indicator?
Likely your only option is to grab one from the junkyard.
Old Apr 4, 2024
Skylo's Avatar
figured as much
do you know if that will come off by itself from the lock assembly or if its together as one?
kinda like the trunk latch cable(which i've disconnected and removed), do you know if i can disconnect the cable from that little lock to replace or...?
Sayword90
Electrical
Sep 10, 2021 06:29 PM
fvckbg
Oct 20, 2016 07:37 PM
BADFNZ
Jul 9, 2007 09:57 AM
endlesssssssss
Jan 17, 2007 03:15 PM
dan502
Jul 28, 2004 02:46 PM
