Interior Post about Interior parts, seats, consoles, etc
04 Si EP3 - Removing Front Passenger Seat
Old Aug 3, 2023
zoom070's Avatar
zoom070 is an unknown quantity at this point
Hey, me again. Looking to remove my front passenger seat on my 2004 Civic Si EP3. Simple enough, but my issue is two: the occupant sensor and the airbag(???).
By airbag I mean the yellow "airbag style" connector(s) under the seat. IIRC there are two of them. Maybe one though. However, my model+year doesn't appear to have seat srs airbags. What are these for? I'm assuming airbags and, if so, will just put a 2.2ohm resistor in the socket.
Next is the passenger occupant sensor/weight sensor. I have no clue what to do here. Just straight jump the pins on the connector?
My goal is to not have the SRS light come on. If it does come on, will it turn itself off once the issues are resolved similar to the abs system?
Old Aug 4, 2023
Colin42's Avatar
Re: 04 Si EP3 - Removing Front Passenger Seat
Why?
safety systems really shouldn't be messed with like that
Old Aug 4, 2023
BrotatoChip's Avatar
Super Moderator
Are you replacing the seats with aftermarket?
Seat belt latch has a switch inside. Looks like when the circuit is open, it thinks the buckle is latched.
Old Aug 4, 2023
zoom070's Avatar
To answer both questions, I'm going to be temporarily living in my car for 2 months or so due to a series of unfortunate events. I desperately need that extra room to get into the back seats to sleep without crawling awkwardly behind the passenger front seat. I also would like to use it's space to place a small foldable table for laptop use.
I will be the only person in the car for the 2 month period and afterwards plan to put the seat back in.
Not set on doing this, just mostly asking about how plausible/possible it is without risk. I did call my insurance company and they had to call a manager(lol) but I was told it shouldn't be an issue.
Old Aug 4, 2023
Super Moderator
I am sorry to hear that. Hope things get better soon.
From the schematic, I would guess the SRS unit either needs to see ground on pin 2 (unbuckled) or pin 3 (buckled) at all times, otherwise throw a fault. Those pin numbers are at the seat connector. What you could do is put a jumper from pin 1 to one of the others. Passenger airbag likely armed if it sees the passenger seat buckled.
Steve_2006
Electronics
Jul 14, 2022 09:33 PM
DoWorkRacing
Apr 29, 2009 01:29 PM
04 Honda Civic
Buy, Sell, & Trade - Archive
May 22, 2007 01:49 PM
turboslug
Oct 24, 2004 02:11 PM
Red2k3Civic
Jun 26, 2002 09:52 PM
