Interior Post about Interior parts, seats, consoles, etc
Gas release cable not working, even with cable repair kit
Old Aug 19, 2022
zatu's Avatar
zatu is an unknown quantity at this point
Question Gas release cable not working, even with cable repair kit
I put this plastic piece on the cable, hoping that it would fix the fuel door release problem.
However, the plastic isn't broken, underneath the white cover piece, and looks totally normal.
I attached the metal hook back into the mechanism and tried to open the fuel door, but nothing. No resistance or pressure.
Old Aug 19, 2022
Colin42's Avatar
Re: Gas release cable not working, even with cable repair kit
You can pop the cable out of the fuel neck area from inside the trunk. Have someone operate the cable while you watch the end. The factory cable isn't that expensive, just tedious to install.
Old Feb 18, 2023
ARBEE's Avatar
ARBEE is an unknown quantity at this point
Got my cable from RockAuto. Detached old cable, attached new cable to old cable and pulled new cable into the car without pulling the entire rear section apart.
Old Feb 21, 2023
AnthNirvanaA1G's Avatar
AnthNirvanaA1G is an unknown quantity at this point
Jacket wasn’t attached to anything? I’m about to do the hood release cable and I already saw two zip-tie clips that I have to pull out
Old Feb 21, 2023
ARBEE's Avatar
Yup. Hood release will be much easier as its shorter and only runs through the firewall.
pjw73nh
Jan 22, 2014 03:09 PM
rarewolf
Aug 6, 2012 06:24 PM
HondaHybridFan
Jul 7, 2011 07:03 AM
Fern
Sep 22, 2004 04:55 PM
