Safety/Security Items - SRS, Keys, Immobilizer, airbags, ABS Post your safety, security questions here! Airbags, Keys (immobilizer)
02 civic si dead
Old 1 Week Ago
PPotopenko's Avatar
PPotopenko is an unknown quantity at this point
02 civic si dead
I have been having an intermittent problem where the car would act like the clutch wasn't pushed in lights all work dash boots up i'd crank it a few times and it would fire. Now its completely dead. i get in the green key stays solid i turn the key 2 seconds later it sounds like the main relay behind the dash pops once and then the green key blinks. i'm going to check fuses when I get home but the fuel pump isn't kicking on either so I can't bump start it either. the only code it reads is p1607 which is a pcm code. Has anyone ever had this happen and how did you fix it? i'm getting really frustrated with it any help would be great.
Old 1 Day Ago
Re: 02 civic si dead
Canadian Si or US Si?
Canadian Si is the EX model in US, Si in US is the hatch
Green key means need reprogramming key, but if PCM issues, if you car is Canadian, it could be loose bolts in alternator, which fries the ECU...
fanboat
Engine start problems
Oct 24, 2024 08:24 AM
Kevinbates24
Dec 16, 2022 06:29 AM
choocheus
Oct 16, 2021 05:19 PM
iceman_1227
Aug 27, 2011 10:54 PM
ohyeah
Sep 20, 2010 09:37 PM
