Safety/Security Items - SRS, Keys, Immobilizer, airbags, ABS Post your safety, security questions here! Airbags, Keys (immobilizer)
Remote lock/unlock problem
Old Jul 21, 2006
chokingvictimva's Avatar
Ideas Are Bullet Proof
chokingvictimva is an unknown quantity at this point
Alright i was working ony my car today,installing front speakers and attempted to install an amplifier. Anyways when all is done i try to lock my car with remote and it doesnt lock it, but the unlock does work, I tried my other remote just make sure,same problem. but it will manually lock from inside and with key. Could it be a problem with a fuse? or is there a problem with driver side door. anyways if any one could help me out .
Old Jul 22, 2006
D5cIvIc's Avatar
Well i have kind of the same problem. My car today worked fined when i turned off the alarm to unlock my doors. Then when i got to work, my driver side auto door lock no longer functions. When i use lock the doors, the passenger side would work with no problems, it just my driver side that is messed up right now. So even with an alarm, i have to either enter in teh passenger side or use my key to open up the driver side. it sucks. I'll have to have my body shop take a look at it. Let me know how it goes with you if you get it fixed
Old Jul 22, 2006
D5cIvIc's Avatar
Old Jul 23, 2006
streetglower's Avatar
If the remote doesnt unlock/lock a certain door, but the key will unlock/lock the door, then more then likely the door lock actuator needs to be replaced. I had to replace mine on the drivers side due to the same issues.
Old Jul 23, 2006
alright cool,thanks for the info,i'll see if i can fix it monday,thanks for the help
Old Jul 23, 2006
also make sure that the electrical connecter was re-connected.
Old Jul 23, 2006
D5cIvIc's Avatar
Can you tell me how much it was for the lock actuator? Did you do it yourself or did you have a professional do it? I tried to take apart the door to see if i could find the source of the problem, but i didn't even knowwhat i was looking for. So when you say actuator, i'm really confused on how it even looks.
Old Jul 23, 2006
Professional, I am the professional. Yes I replaced it myself. If you remove the door panel, look on the side of the door where the I believe it is 3 large bolts and the actuator sits toward the bottom in that area. If its the drivers door, it is in the left bottom corner.
Remove the door panel and reconnect everything and hit the lock/unlcok button and see if you can hear the actuator.
I replaced the door lock assembly which includes the actuator. It was about $45. the actuator itself is around $20, but I couldnt figure out how to remove it from the lock assembly.
Old Jul 23, 2006
D5cIvIc's Avatar
^^ where did you buy the whole door lock assembly from?
Old Jul 23, 2006
www.hondaautomotiveparts.com
http://www.hondaautomotiveparts.com/...gry5=DOOR+LOCK
number 31
PinkCupcakes
Electronics
Jul 18, 2019 12:50 PM
Civic2002lx
Oct 7, 2015 09:17 AM
davidarenberg
May 16, 2015 08:45 AM
MamaBear2015
May 3, 2015 02:17 PM
carhag2000
Apr 25, 2015 01:33 PM
