washer in wrong spot on subframe [solved]
Old Jan 13, 2022
Millsy088's Avatar
Millsy088 is an unknown quantity at this point
hi there, so after putting my subframe back in i must have put the washer on the wrong side of this bolt, can i just undo that bolt and try and pry the washer out so i can put it on the other side and then check the tightness of the main 4 subframe bolts or will that throw off the suspension or something? i really hope i dont have to take the subframe out as i noticed this on the final check before i start and drive the car
the one where i believe the washer is in the wrong spot
the other side (right side) where i believe i got it right
Old Jan 13, 2022
re: washer in wrong spot on subframe [solved]
see the darker mark where you don't have dirty?
that's where the washer used to be. so wrong side.
I would fix that...
Old Jan 13, 2022
Millsy088's Avatar
I would fix that...
Yes yes of course but I'm asking if I have to drop the whole subframe or if I can undo the bolt, then try and slide the washer out with a screwdriver or something as I imagine it could be in there tight, I reckon I could do that but would that minor adjustment mess with the alignment of the subframe or suspension?
Old Jan 13, 2022
you can loosen or just that one and try, if not, loosen all the bolts and try again
Old Jan 13, 2022
Colin42's Avatar
Loosen all the bolts, remove the wrong one and fix
Old Jan 13, 2022
Millsy088's Avatar
So I can loosen all the subframe bolts with out it dropping down?
Old Jan 14, 2022
we said loosen, not remove...
Old Jan 14, 2022
Millsy088's Avatar
Yep too easy, I did all that, had to remove the engine mounts on the subframe but it did end up working thanks!
Old Jan 14, 2022
BrotatoChip's Avatar
Super Moderator
Re: washer in wrong spot on subframe [solved]
That bolts to a bracket, that bracket bolts to the "frame". Can't you just loosen the two bolts holding that bracket to the body to get the washer out?
Old Jan 15, 2022
Millsy088's Avatar
in retrospect I probably could have, however, the washer was being a real pain and getting jammed on the bolt, stopping me from removing it, so I dropped the subframe low enough to the point where the washer would clear it, although I probably could have tried to remove the bracket from the body first, would have saved me a fair bit of time haha
AlpineCivic
South Cali
Dec 15, 2004 09:40 PM
nytejade
16
Dec 4, 2002 01:42 PM
ohmysac
Nov 18, 2002 10:24 AM
civicck02
May 21, 2002 01:24 AM
