Em2 civic toe problems
Old Jun 6, 2020
gpxoxo's Avatar
gpxoxo is an unknown quantity at this point
So I have a 02 civic em2 I’m currently running truharts for suspension with camber plates. At first I had awesome fitment with a straight wheel alignment. Just recently I hit a crazy pot hole and it knocked my alignment out, I’ve taken it to two spots only one can give me a reason why they can’t align them. He said my drivers side outer tire rods need more threads and recommended me to look into rsx parts. My question is how do I fixed my toe on these cars if it’s maxed out?
Old Jun 7, 2020
Re: Em2 civic toe problems
how low? change height and the distance steer box to suspension changes.
moved thread to correct generation. 7th gen have very different suspension vs 1-5th and 6th gen cars
Old Jun 7, 2020
gpxoxo's Avatar
thank you my brother lol new civic owner things, I’m slammed but the thing is I rub on my drivers side because of how untucked I am because of my toe issue.
Old Jun 8, 2020
BrotatoChip's Avatar
Super Moderator
When you hit the pot hole did it by chance bend the strut? That's about the only thing I can think of that would then make the tie rods not long enough.
Old Jun 8, 2020
it's well known issue when slammed. RSX tie-rods will bolt from the bottom, while civic are on the top. thus it's not as far compared with civic tie-rod ends.
there are a few threads around if you search for them.
Old Feb 17, 2021
LittleTicoy's Avatar
LittleTicoy is an unknown quantity at this point
Recently had my 04 EM2 aligned and they said the same thing. They mentioned if my steering was ever removed which I said no. I have a set of KSport Kontrol Pro coil overs on mine.
anybody found a solution to this?
Old Feb 17, 2021
very low?
EM2love
General 7th Gen
Jul 18, 2009 09:41 AM
Dre4meR
Jun 29, 2009 10:37 PM
CDN-Retard
May 16, 2009 07:42 PM
PandaEM2
General 7th Gen
Feb 24, 2008 01:03 AM
DAQIUN
May 30, 2006 10:48 PM
