I have another rear suspension bushing question
Old Oct 19, 2019
Nohippychicks's Avatar
Nohippychicks is an unknown quantity at this point
I posted a couple times asking about suspension bushings; I got help, part numbers and installed them. Moving on, I'd like to go ahead and replace the rest of the rear bushings.
Looking at the part numbers here, I have changed out reference numbers 18 and 32. Part numbers for 11, 12 and 13 are easy enough, but the lower forward bushing (Just above number 27) is a mystery. Is it not typically changed out?
Also, while you're there, can you tell me if the part numbers for left and right are the same? It seems like they are, but under the link to each part, I see "RR," which sounds like "Right rear," to me. I would like to be sure before pulling the trigger on the parts.
Old Oct 20, 2019
GolNat's Avatar
Prelude Owner
Re: I have another rear suspension bushing question
That bushing is not typically replaced. I think you can buy aftermarket bushings for it though (I think).
If the part numbers are different then they probably are different from side to side.
Old Oct 21, 2019
BrotatoChip's Avatar
Super Moderator
There isn't a specific part number for those bushings, and the service manual doesn't mention replacing it separately. I think the entire trailing arm has to be replaced to get that bushing.
Old Oct 22, 2019
Thanks! I got the rest of the parts on order.
mwhit0
Suspension
May 15, 2019 04:07 PM
mfskarphedin
23
Jan 17, 2015 10:34 PM
Foffie
Nov 21, 2010 06:20 PM
chopper202
Mar 30, 2007 04:46 AM
jdm_bb
Jul 22, 2005 02:10 PM
