Slight pulling left/right while driving
Old Feb 12, 2018
03_EM2's Avatar
03_EM2 is an unknown quantity at this point
Just picked up a 03 EM2 Coupe 5-speed a few days ago and when I’m driving under low throttle or just coasting (haven’t tried hard accelerations yet figured best not to) the car seems to have some play or looseness in the steering. It also has a little knocking coming from the right front wheel area, guy told me it was just bad control arm bushings and I believe that to be true. Could these control arm bushings be causing the looseness in the steering? It doesn’t feel related to the rear in any way. Also for an extra bit of info it’s on ESM-007 17x9, not 100% on offset since I haven’t got down to look yet.
Old Feb 12, 2018
Colin42's Avatar
Re: Slight pulling left/right while driving
bad control arm bushings can certainly give steering issues
Old Feb 12, 2018
03_EM2's Avatar
appreciate the feedback. I’ll replace the bushings and see if that takes care of all problems, didn’t know if it might be because of such a large/wide wheel size.
Old Feb 15, 2018
D17VTECPOWER's Avatar
D17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of light
Bad control arm bushings will definitely cause problems with the steering. Also, check your ball joints and tie rod ends too. Bad tie rod ends or ball joints can definitely cause noise and play in the steering, and will effect the alignment.
Old Feb 15, 2018
Put the original and correct wheels and tires back on the car and see if it drives normally.
Lots of wheel offset in either direction can cause weird wander issues, like the car is trying to follow ruts in the pavement.....or trying to climb up out of the ruts in the pavement
Square shouldered tires can try to follow lines and uneven surfaces in the pavement
Old Feb 15, 2018
GolNat's Avatar
Prelude Owner
17x9 is a big wheel!!! There are lots of suspension parts that when worn can cause issues but those wheels probably have a big offset if they are 9” wide.
Is it lowered?
Old Feb 16, 2018
03_EM2's Avatar
Is it lowered?
No the car isn’t lowered any, and sits like a monster truck. Still rubs slightly on one rear wheel when cornering. Haven’t had the car long so it hasn’t had the wheels off to check for wear and tear on suspension components. Looking to go for coilovers a lil later down the road, anyone recommend any good kits? And I bought the car with the wheels and tires on it didn’t include the stocks.
Old Feb 16, 2018
Colin42's Avatar
does it have a rear sway bar?
Old Feb 16, 2018
03_EM2's Avatar
I’m fairly certain the car came stock with a rear sway bar? It most likely still has the stock one which I’ve heard are really small so I might look into getting a new one. I haven’t had the car long so I haven’t taken the time to look under it at any of the suspension components, he told me it needed new front control arm bushings for sure but that was all he knew. He had just replaced the head and gaskets since he bought the car with a blown head gasket. He said it will sometimes throw the P0401 code. He said it wasn’t the EGR valve itself but was unsure what the exact problem was..
Old Feb 16, 2018
Typical repair: Intake manifold must be pulled out so the EGR passages can be cleaned of carbon buildup.
Or he installed the wrong intake gasket when he did the head gasket.
Peege777
Air Conditioning
Oct 10, 2019 05:32 PM
Luke Szabolcsky
Suspension
Sep 16, 2017 06:27 PM
Thaik
22
Jul 27, 2014 10:20 PM
2002ExCivic
Feb 6, 2014 01:01 AM
05blueexcoupe
Aug 14, 2009 10:07 PM
