Another Lower Ball Joint Thread: Separating from LCA
Old Aug 18, 2016
dnmacdon's Avatar
dnmacdon is an unknown quantity at this point
So I've successfully changed out two front lower ball joints on a 2005 Civic recently. On this car (2004 LX 4 door), I wasn't able to get the ball joint to separate. The ultimate goal was to remove the drive axles and transmission so I ended up biting the bullet and removing the knuckle-to-strut mounting bolts, which I was trying to avoid.
I tried what's worked for me in the in the past, a pivoting ball joint tool that looks similar to the one in the service manual. No pop, but it did start to mushroom the end of the stud a little. So I tried the jack-and-insert-ratchet trick, no pop. Tried "beating the snot out of it" (as a wise man once wrote) with a sledge (to the LCA), and tried doing the same while a helper reefed on it with a pry bar. Nothing. I've tried each of these two or three times. Spent over an hour, maybe two on this ******* ball joint.
It's the original, 12-year old, OEM ball joint and LCA, although the other side popped out with the ball joint tool no problem. I'm at a loss. I do need to replace it as there's now some play. Any help would be appreciated!
Old Aug 18, 2016
Re: Another Lower Ball Joint Thread: Separating from LCA
If it has to be replaced, get a pickle fork.
Old Aug 18, 2016
guitarsnlikker's Avatar
guitarsnlikker is an unknown quantity at this point
pickle fork worked on my 11 year old original ball joints.
Old Aug 18, 2016
left mine for days, soaking everyday and tightening the tool everyday. then, one day, i heard a bang from the garage. it was finally out.
Old Aug 19, 2016
Colin42's Avatar
heat helps too
Old Aug 19, 2016
mikey1's Avatar
no ball joint is any competition for a pickle fork and sledge hammer
Old Aug 19, 2016
Colin42's Avatar
one of mine was
Old Aug 19, 2016
mikey1's Avatar
Originally Posted by Colin42
one of mine was
your not strong enough
Old Aug 19, 2016
Colin42's Avatar
we broke the pickle fork
Old Aug 19, 2016
dnmacdon's Avatar
Yeah, the trouble I'm having with the pickle forks is that they're not tall enough. I've got a set of five on loan from a local auto parts store and none are quite thick enough to put pressure on the LCA and knuckle. I guess the gap is larger on Hondas than on other cars? I'll go looking for a bigger pickle fork I guess.
I'll also give heat a try. I only have access to a propane torch but I'll give it a shot, heat the LCA and see if it does the trick.
I've also been trying the sustained pressure trick, had the balljoint tool on there for the last couple of days, as tight as I can make it. I'll keep this up too if the others don't work.
So that's three plans of attack. Place your bets...
Old Aug 19, 2016
Colin42's Avatar
keep the pressure on and then hit it with the heat, it will probably let go
Old Aug 19, 2016
dnmacdon's Avatar
Propane torch + pressure from the ball joint separator = burning rubber + one popped ball joint.
Heat was the thing. Thanks everybody!
Old Aug 19, 2016
dnmacdon's Avatar
Now that I think about it, given all the pounding with a sledge, do I need to be concerned about the integrity of the control arm? I'll have a look for obvious cracks, anything else I should check for?
Thanks again!
Old Aug 19, 2016
Great!
About the lca, if you find you can't get alignment, it could have bent...
120 bucks with bushings was what I paid.several years ago
MajTom
Electrical
Oct 16, 2021 08:47 AM
bgtg
Electrical
Nov 4, 2015 06:14 PM
danfry21
Oct 31, 2015 02:26 PM
ernie22lord
Oct 26, 2015 12:01 PM
bhamdodger
Oct 22, 2015 07:56 PM
