Struts
Old Mar 9, 2016
halava's Avatar
halava is an unknown quantity at this point
Struts
Good day, gentlemen. I have recently purchased a 2001 Honda Civic LX standard transmission with 181,000 miles. I need new struts for the two front wheels. I won't be doing the work myself, but will be purchasing the parts. As you know, I have the option of just buying struts or buying the full assembly with shocks and mounts. I don't have top money to spend but also don't want to get the cheapest quality out there. Looking for advice on what brands are good and also where to buy them. Thank you in advance.
Old Mar 10, 2016
Poopies's Avatar
Super Moderator
Re: Struts
Hi! Coilovers tend to be expensive so replacing the struts is the way to go. Tokico HP (blue) are considered OEM replacement. You can find a pair on eBay in the $200s.
Old Mar 10, 2016
PatrickR's Avatar
PatrickR is an unknown quantity at this point
Re: Struts
Struts work best. If you are having someone else perform the work is going to cost more $$$ for you. Tokico, Koni, or KYB are all great brand. Changing them yourself will save you $$.
02 civic (night rider)
Old Mar 11, 2016
halava's Avatar
Re: Struts
Thank you very much, gentlemen. I would love to save the money and do the work myself but I am not that mechanically knowledgeable and don't have any tools. Thanks for pointing me in the right direction. I guess I will replace the whole strut assembly.
Old Mar 11, 2016
Poopies's Avatar
Super Moderator
Re: Struts
Remember, your springs should be good for the lifetime of the car. Make sure you replace the "hats" as well! At least parts 10&11 here:
http://estore.honda.com/honda/parts/...n=&b=B++28&dl=
Old Mar 12, 2016
halava's Avatar
Re: Struts
Are the 'hats' possibly called the 'mounts' as well? When I buy the whole assembly, it comes with springs (with strut and mount, of course ) Are you saying I don't need to replace the spring and should just buy struts, and 'hats'? Also I hear replacing the whole assembly is less work and therefore cheaper to do.
shriketheavatar
Oct 20, 2015 08:31 PM
bobby08
Electronics
Oct 19, 2015 09:27 PM
samalex
Wheels and Tires
Oct 7, 2015 12:33 AM
thatcham
Sep 30, 2015 08:28 AM
Bartkat
20
Feb 19, 2002 01:29 PM
