Replacement Bolts for LCA's
Old Nov 11, 2015
rollaguy's Avatar
rollaguy is an unknown quantity at this point
Has anyone used the original stock 10 spline bolts with their aftermarket LCA's? I know this isn't recommended, but the bolts supplied by the store did not fit & I don't want alter the threads on the knuckle.
What is a good replacement bolt because Honda is having a very hard time determining this????
Thanks for the help anyone!!!!
Old Nov 11, 2015
Re: Replacement Bolts for LCA's
is your car a 01-02 and the lca's for 03-05? Or vice versa? 01/02 uses 14 mm for the knuckle crash bolts, 03+ uses 16 mm and larger shock bodies (50mm vs 55?)
Old Nov 11, 2015
rollaguy's Avatar
I have an 01 civic lx and the lca's should be for an 01. They aren't skunk2 or megan racing control arms, but was looking to see if I could still use the factory bolts with some threadlocker?
cgriffin51
Oct 31, 2015 03:43 PM
greenbean209
Suspension
Oct 28, 2015 09:17 AM
2002ExCivic
22
Sep 28, 2015 08:29 AM
7thgensurvivor
33
Sep 5, 2015 08:20 PM
