Brakes Post Your questions about brakes here!
Break lines
Old May 21, 2022
Benrudd521's Avatar
Benrudd521 is an unknown quantity at this point
Break lines
What lines do i need for a 03 LX my lines are bad under the master cylinder the lines are under a chassis brace
Old May 21, 2022
Colin42's Avatar
Re: Break lines
Should be 3/16" line with 10mm double bubble. Use copper-nickel line
Old May 21, 2022
Benrudd521's Avatar
Re: Break lines
Thanks man!
Old Dec 6, 2022
Simcoewaters's Avatar
Simcoewaters is a jewel in the roughSimcoewaters is a jewel in the roughSimcoewaters is a jewel in the rough
Re: Break lines
We replaced the lines on a civic 2003 DX. The flares were referred to as bubble flares. We replaced the sections going to the proportioner. These sections were corroded. When we ran two new rear lines from the proportioner to join the two rear steel brake lines we had a problem. The flare tool would not flare the metal line adequately. I bought a Titan tool 51535. This tool does double inverted flares. So these joints/ unions were double inverted flares. The other end of the nickel copper brake line was bubble flared and attached to the proportioner.. In an effort to proceed quickly we cut the lines from the proportioner. We ran into a small problem in that we could not recall routing or placement of the M1 or M2 lines in relation to the master cylinder. As it was the M1 goes to what some diagrams call the circuit 1 side. The side without the protruding push rod. I verified this by going to the wreckers, I have photos I can upload.
Old Dec 6, 2022
Colin42's Avatar
Re: Break lines
Go to a site like hondapartsnow.com look at the diagram for the brake lines, should show you where
Joe Mama5291
Brakes
Aug 22, 2020 07:16 PM
thewal
Oct 27, 2010 01:59 PM
Rufus
Jan 18, 2009 04:24 PM
linsook
Apr 2, 2006 10:32 PM
CuRiOuSfIsH
Jan 7, 2004 11:31 PM
