ABS light and Brake light problem?
i have a 2005 civic ex coupe. i just noticed the other day that my lights on my dash guages are on. the ABS light and the light that says BRAKE. i rained like 5 days ago and i thought maybe because it was wet, it turned on. but it has been dry for a long time now and the lights are still on. they never used to be on. is something wrong? how do i get them to turn off?
first check your brake fluid level in the resovoir. if its fine, you need to have it checked. either a wheel speed sensor or hydraulic unit failure. either way, arent you under warranty?
twtron
Apr 17, 2015 12:09 AM
