Brakes Post Your questions about brakes here!
squeaky brakes?
Old Feb 16, 2005
ravolutionazx's Avatar
ravolutionazx has a little shameless behaviour in the past
squeaky brakes?
now i know i may sound like a complete idiot when i ask this but its worth a shot with you good people lol. im guessing that its that i need new brake pads but my left wheel makes squeaking sounds as i drive and goes away when im not moving.. its my first car so i dont know the basics of changing brake pads sorry lol but if someone could help me out
Old Feb 17, 2005
Leets's Avatar
Leets is an unknown quantity at this point
It is your pads if you you only hear it while breaking. They're designed to make a squealing noise as you brake so that you know when they need to be replaced. If the sound occurs everytime the wheel is spinning, even when the brakes aren't being applied, then you need to have your wheel bearings inspected. Although, considering Honda uses really good bearings that don't tend to go out prior to 100K miles that most likely isn't the case with your current situation. Hope that helps.
Old Feb 17, 2005
what exactly do the brake pads look like while they're on the caliper? just curious.. i look at my calipers and i get lost..
Old Feb 17, 2005
Leets's Avatar
They are the pieces that rest agains the rotor (disc). The caliper works as a mechanical claw or clamp and presses the pads against the disc.
Old Feb 17, 2005
opticalvetc's Avatar
opticalvetc is an unknown quantity at this point
the brakes can still make noise whether your breaking or not. If the pads are down low enough the squeelers will be touching the rotor all the time, not just when your braking. How many K's on the car?
Old Feb 17, 2005
about 52K? how much should it cost to get replaced? or can you do it yourself?
Old Feb 17, 2005
Leets's Avatar
It should be noted that if this is the case then:
A.) why have you been driving around with squealing brakes for so long that they've now become fully contacted with the rotor and
B.) you will need to look into new rotors.
Many people will tell you that this isn't true and you just need to resurface the rotor. However, the truth is that if the rotor is damaged in any way (such as metal to metal contact caused by the fully ground pad in continuous contact with the rotor) it should be replaced. What many people don't realize is that, although it is considerably cheaper, resurfacing the rotors decreases their overall thickness. Rotor thickness is essential to heat dissipation. Reducing the thickness of the rotor deteriorates from the rotor's heat dissipation efficiency. There is a certain thickness that the manufacturer still deems safe, making it possible to safely resurface the rotor to a point. Although the rotors will still remain intact (resist cracking) up to this point, they will not perform as effectively through high heat cycles as full thickness rotors. Hope that gives you some information to ponder.
Old Feb 20, 2005
I've done my own pads and rotor replacement. Its pretty easy if you know what your doing. You can get it done for around $150. if your at 52K you have done pretty well on a set of front brakes. So many people kill them about 20K.
Old Aug 22, 2022
Tristan Civic's Avatar
Tristan Civic is an unknown quantity at this point
Re: squeaky brakes?
Hey this is 2022 and you're the top result for this issue on Google. I highly recommend greasing your brake components everytime you change your pads &or rotors. The main component to constant squeaking after a brake pad change is the clip youre provided with. Let's day you didn't switch out the clip because someone gave you bad advice or just didn't feel like it. Grease the thing up at the very least, ok? That clip serves as the holder for the pad to slide in back and forth with the help of the caliper. Without grease you most likely won't get any movement on the brake pad. Especially if you've got an old clip. Take care good luck
Old Aug 22, 2022
Colin42's Avatar
Re: squeaky brakes?
This thread is 17 years old.....
Old Oct 6, 2022
SamBurritos's Avatar
SamBurritos is an unknown quantity at this point
Re: squeaky brakes?
It just helped me. Google makes time and space irrelevant.
Bricoleur
Sep 9, 2015 06:48 PM
vImpostor
Vancouver
Sep 8, 2015 08:08 PM
thaler4cuse
Sep 7, 2015 08:25 PM
Josh 1973
Sep 7, 2015 10:10 AM
rainman15
Sep 6, 2015 11:10 AM
