Idle Issues If you have idle issues, post here!
initial stalling driving issue
Old Apr 15, 2022
Norm1234's Avatar
Norm1234 is an unknown quantity at this point
Did some searching but could not find anything, 2003 Civic non VTEC, cranks up runs just fine start to drive and about 60 seconds later vehicle acts like it's running out of gas but does not completely stall out just very low RPMs. After a couple seconds vehicle returns to normal and runs just fine for the duration of the trip. Shut vehicle off wait an hour problems starts all over again.
Note: there are not fault codes.
Old Apr 15, 2022
Colin42's Avatar
Re: initial stalling driving issue
Try cleaning out the iac valve. Do not buy a new aftermarket one, either buy new oem or get a used one from the junkyard
Old Apr 15, 2022
Norm1234's Avatar
Okay, went to the salvage yard picked up a new throttle body assembly. Disassemble to include idle control valve, put in ultrasonic cleaner and got it looking like new inside and out. Reassembled salvaged throttle body and put back on vehicle and same problem still exist
However I did have my OBD2 scanner hooked up on live data at the time and for some odd reason my short-term fuel trim went to over -20%. Whatever is going on the computer is intentionally taking away fuel creating a stall.
Old Apr 15, 2022
Colin42's Avatar
Unplug the primary o2 sensor and see what happens
Old Apr 16, 2022
Norm1234's Avatar
First trip today and no stalling with upstream O2 sensor unplug. Will drive this way for a few days and see what happens.
Old Apr 16, 2022
Colin42's Avatar
Make sure you buy the correct Denso o2 sensor
95dxFamilyMan
Detailing
Feb 28, 2013 08:52 PM
thecount
Aug 2, 2012 10:00 AM
dwils
Oct 24, 2010 11:53 PM
94cdx
Jun 23, 2010 10:52 PM
