Idle Issues If you have idle issues, post here!
Misfire at cold start only.
Old Jan 31, 2020
JGrill's Avatar
JGrill is an unknown quantity at this point
Hi all, my 03 ex has a cylinder 1 misfire on cold start. car is bone stock. Over the past few days I have adjusted the valves and replaced the plugs. I Have yet to do a compression test at this point. As I said it only will misfire on cold start (after sitting overnight) and will not misfire on cold start if it sits in my garage overnight. Also, if I race the engine up off idle the misfire goes away immediately and doesn’t return. Just looking for some ideas.
Old Jan 31, 2020
BrotatoChip's Avatar
Super Moderator
Re: Misfire at cold start only.
Coolant leaking into cylinder after sitting overnight?
Old Jan 31, 2020
JGrill's Avatar
I definitely think that’s a possibility, but as I said in my post, if I leave it in the shop overnight (55* vs 18*) there is no misfire on cold start. It’s really strange. When I did plugs I moved could around, and the misfire returns to cylinder 1 which does make the head gasket thing probable, however the plugs had zero sign of deposits on them. Compression testing and leaking down now to see what I get.
Old Jan 31, 2020
JGrill's Avatar
Old Jan 31, 2020
Colin42's Avatar
Definitely something up with cylinder 1
Old Feb 1, 2020
Super Moderator
Time to try a leak down test to narrow it down.
JanglinJ
Aug 8, 2017 03:25 PM
whitelight75
Jul 8, 2014 09:08 PM
CivicRider
Apr 27, 2014 10:51 AM
[H]ondaCivic
Jun 2, 2013 01:30 PM
civic02ex
Sep 27, 2005 06:32 PM
