Idle Issues If you have idle issues, post here!
erratic idle
Old Dec 23, 2017
john donovan's Avatar
john donovan is an unknown quantity at this point
erratic idle
new head gasket head checked and planed new timing belt tensioner water pump and coolant temp sensor new antifreeze raised front end to get air out car starts and runs smooth till it warms up then it has an erratic idle up and down on its own I also tried the relearn with no results hopefully someone has some advice
Old Dec 23, 2017
Re: erratic idle
Reach into the throttle body and plug the open port with your fingertip. Does that bring the idle down to normal RPM or below?
If so, IAC is probably stuck open.
If not, then look for vacuum leaks.
Old Dec 23, 2017
Slumpertcivic's Avatar
Re: erratic idle
First thought is a air leak.
You pulled apart lots of joints and pulled off lots vacuum hoses.
Old Dec 23, 2017
Re: erratic idle
checked all lines for vacuum leaks I will try your advice tomorrow ezone thanks for the help all and Merry Christmas
Old Dec 23, 2017
Wankenstein's Avatar
Re: erratic idle
Which method(s) did you use to check for vacuum leaks?
Old Dec 27, 2017
anthonyelectric's Avatar
anthonyelectric is an unknown quantity at this point
Re: erratic idle
Any update? I have a wild idle that only happens once in a while!
Old Dec 27, 2017
Re: erratic idle
Please start a new thread which describes your car's specific issue. Aslo include year/model/mileage/transmission type. Thank you.
Old Jan 30, 2018
Re: erratic idle
sorry for delay but I work away from home for weeks at a time anyway I changed throttle body and sprayed everything with throttle body cleaner all injectors drop when unplugged same with coil packs did a smoke test still nothing friend of mine works for Honda says it may need a scan toll to adjust it but it still idles at 1000 to 3000 steadily up and down stays around 900 when you put it in gear with torque on it when he puts his scan tool on it I will update
Old Jan 30, 2018
Re: erratic idle
Used throttle body might have a stuck IAC, just like your original might have a stuck IAC.
Old Apr 7, 2019
2005ex's Avatar
Lstafford
2005ex is an unknown quantity at this point
Re: erratic idle
Sorry for this post. I didn't mean to post on this thread but dont know how to delete it lol. Well guys, any more suggestions before I go crazy lol. I've replaced the air fuel ratio sensor with the OEM Denso. I've replaced the map sensor. Fixed a small exhaust leak right off the header. The only code it is showing now is for the catylic converter which makes sense because it doesn't have one but my problem has not gotten any better. I cant hear any vacuum leaks either. It still surges up and down a couple of times then levels out at idle. When i press the accelerator it surges a couple more times and idles correctly. Also when driving, when i press the clutch the rpms increase instead of falling out. I dont know what else to do next
Old Apr 8, 2019
Re: erratic idle
Maybe a failing TPS sensor? Do you have a live data reader that can show you details such as throttle position and what the computer is being told for coolant temperature?
Old Apr 8, 2019
2005ex's Avatar
Lstafford
Re: erratic idle
Not saying you are wrong but I just replaced that and calibrated it. I sure don't not have a live scanner either
CNTLOSE
16
Nov 14, 2014 07:23 AM
yllager2013
Apr 17, 2013 12:41 PM
user 82334534
Dec 27, 2011 02:14 AM
HommeDeBois
Aug 15, 2011 11:49 AM
firstforme
Jul 16, 2010 11:33 AM
