BMXA Shifting Issue
Old Apr 12, 2024
Elly's Avatar
Elly is an unknown quantity at this point
BMXA Shifting Issue
I've a 2003 1.7L with BMXA auto trans. Shifts up and down OK except for going up from 2nd to 3rd when there is a flare in the rpm. Goes into gear eventually (slow to change) or if I back off the gas a little. Replaced correct amount and type of fluid (Honda ATF). Replaced the double solenoid block on the front of the trans. Also has a slight whine when cold and in neutral but lessens when put into drive. Any suggestions before I take to pulling the unit and doing an internal inspection or rebuild?
Thanks.
Old Apr 12, 2024
chozobody's Avatar
chozobody is an unknown quantity at this point
Re: BMXA Shifting Issue
Sounds like a typical 7th gen AT failure issue to me.
Old Apr 12, 2024
chozobody's Avatar
Check out this post, where someone went into a root cause analysis on the 7th gen AT. 7th Generation Transmission - failure cause investigation - Honda Civic Forum (civicforums.com)
Old Apr 20, 2024
Elly's Avatar
Thanks everyone, I'll rip into it and report what I find.
Old Dec 2, 2024
kurtbarlow's Avatar
kurtbarlow is an unknown quantity at this point
Are there any DTC codes?
Try changing the solenoids in the passenger side, they are AB shift solenoids.
john_rodgers321
Transmission
Mar 22, 2022 06:22 AM
larrysmith
Apr 8, 2012 01:18 AM
JeremyE
Feb 11, 2011 10:43 PM
Lou2010
Aug 25, 2010 07:54 PM
LQ9Chevelle
Mar 2, 2009 02:45 PM
