Transmission compatibility
A friend has a Civic Vision, 2002, with the 1396cc engine and now with a failing gearbox. Rather than scrapping it I am looking in to seeing if a replacement gearbox is a viable option. Our local scrap yard has one for a 1.6 MK7, apart from the gear ratios being different would this be a compatible fit?
Re: Transmission compatibility
Physically they should bolt up as long as they're from the same engine family. Connectors should be the same as well. I would take photos of all the connectors and compare them to what's on the junkyard trans
Kfarron1
Sep 8, 2012 04:59 PM
mrgadfly
Aug 21, 2010 07:16 PM
GonePostal
Sep 13, 2004 08:23 AM
