Torque specs
Torque specs
I have a 2003 Honda Civic EX BMXA trans….Does anyone know the torque specs for the 3 solenoids that sit on the transmission??? I can post pics of the 3 I removed if need be….but I removed and cleaned the single one that sits by like the side of the motor….I removed the one that has 2 solenoids and a single plug and wire to each and also the solenoid that sits down at the bottom with the brown and black plug to it…..putting them back on and would like to know the torque specs if anyone knows….thanks
Re: Torque specs
The specs on this chart (link below) should help. Maybe find other metric bolt charts to compare/confirm per the size and grade bolt for your transmission. https://www.gtsparkplugs.com/bolt-to...rt-metric.html
Goldenvoice
Aug 1, 2016 05:29 PM
