metal on metal sound
Just installed a "new to you" manual 5 speed in my Civic. Install went great! Sub frame and all. Took it out for test drive and shifts awesome with new clutch and fly wheel. BUT,.... there is a funny noise in first and second gear when decelerating at low speeds?? Very low sounding rub noise, but when you accelerate sound is gone! Also, when you push the clutch in,......sound is gone? The sound is like a bent dust plate rubbing on a brake rotor. Any ideas from all you civic folks??
Re: metal on metal sound
Jacked up the car, spun the front wheels no noise from dust shields, for sure noise is still there but gone when clutch pedal is pushed in
Received 1,450 Likes
Rep Power: 339 Re: metal on metal sound
you might need to open it up again...
input shaft bearing? buyer beware I guess. very strange its only is heard when no load is put on tranny and stops when clutch is depressed between 1st and 2nd. Thanks for the intel. I bought the tranny from wreckers, paid a little extra cause it was sitting on shelf ready for install, said 30 day warranty, so Im going to bring car to them, maybe they will honour a refund??? Thanks for info
Received 1,131 Likes
Rep Power: 192 Re: metal on metal sound
Unfortunately it's pretty common with the 7th gens
more info here: https://www.civicforums.com/forums/1...save-some.html
Hey Colin42 thanks for the link
this was sent in your link - -put the car into neutral, and take your foot off the clutch pedal
---- if you hear the noise now, it is the INPUT SHAFT BEARING. if you press in the clutch, the noise should go away.
my Civic problem --- car in neutral, foot off the clutch pedal, no noise --- put car in gear, clutch in, no noise --- drive the car in 1st or 2nd gear,.... take your foot off the accelerator ----- noise ---- press in clutch no noise
got me
got me
Click Here
Received 1,157 Likes
Rep Power: 99 Re: metal on metal sound
See what happens when you go back to the junkyard. Sounds like either a failed bearing like Colin mentioned or one of the internal shafts are misaligned, making contact with 1st and 2nd gear.
I hope they honour what they said "If problem with tranny, 100% money back" !! But to me, they always say "it must of been the install" and they give you the input shaft alright!!!!
Crappy part is, I took my time, cleaned all the parts, was very thorough. Put in knew clutch, flywheel turned, ball joints, lower control arm bushings, struts, brakes and rotors, oil pan gasket, rear main seal and 2 motor mounts. Was all excited that the "PLAN" came together. Started the car, went for a drive, shifted beautiful, no leaks, clutch felt great then,......slowed to a stop sign in gear, foot off the throttle and heard the grind???!!! WTF!!
Now I will drive it with the stereo turned up. I do not want to go through that again! Hopefully get my money back, but I doubt it? The tranny was bought from a junkyard dog!! Grrrrrr.
abber
03-24-2015 08:15 PM
Najitsu
19
08-22-2014 07:14 PM
