2002 Civic JDM transmission question
Old Oct 14, 2021
Jonnylightning's Avatar
Jonnylightning is an unknown quantity at this point
I have been working on my buddys 2002 Civic and he bought a 52,000 mile transmission from Japan. The stock axle boot ripped earlier this year when I put the car into gear and was making banging noises. I measured it as best as I could and ordered the longest axle they had for the passenger side on rock auto. While on the stand the car engaged like it should and went into reverse and drive smoothly. Yesterday I took the car off the jackstands and I put it into gear and it didnt move amd was making these banging noises. I just dont know if a right hand car transmission on a American made Civic would require a special size axle or if this is actually the transmission having problems or the torque converter. Transmission fluid is at level.
Old Nov 21, 2021
D17VTECPOWER's Avatar
D17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of light
Re: 2002 Civic JDM transmission question
The axles are the same for US and JDM transmissions but different for manual and automatic. If the axles are fully seated, it sounds like the problem is the transmission itself. Maybe it can spin the wheels freely when there is no load on it (jacked up) but is failing under load when you try to drive it.
topnotch7gen
Jul 15, 2007 01:27 AM
Mike4831
Jan 9, 2005 09:34 PM
joedc5
Jan 3, 2004 08:48 PM
2001civ
Nov 30, 2003 10:55 PM
keffin
Dec 17, 2002 12:42 PM
